Reducing Servo travel...Help
TN
I have a Seamaster 40, almost done. Now, I set up the servo with the recommended servo double stick tape. I have a new Lazer 4 HiTec radio and servos. Its going to rip this poor servo off the tape. The throttle is opening and closing alright...too much. How can I reduce the travel ???? Help. I have tried different holes in the servo arms and all. not going to cut it. Thanks.
Moderator
My Feedback: (58)
Re: Reducing Servo travel...Help
1) shorten the push rod ? or......
2) remove the servo horn and rotate it back one spline further from the engine ? or......
3) drill another hole on the servo horn
If you have a computer radio, this can be solved easily with the travel limit function
TN
Re: Re: Reducing Servo travel...Help
Originally posted by rajul
Some suggestions :
Some suggestions :
TN
Re: Re: Re: Reducing Servo travel...Help
If you shorten the rod, you just moved the servo closer to the engine/carb. Thanks for the help. No computer radio
NB, CANADA
Move the rod to a position closest to the hub of the servo arm - drill another hole if necessary. Otherwise (or as well) move the rod to the hole on the throttle linkage furthest from the center of the throttle arm. One of these should do the trick!
Ross
Ross
NY
Sure it's called ATV, not sure if that particular radio has it but even if it does you really shouldn't use it. Because if you get a radio glitch in air it'll definitly be passed the radio's ATV limit and might close the throttle all the way (killing engine in flight)
TN
I soldered an extension arm on the throttle. I had no choice. Weird. I had the servo horn all the way in until it was near hitting the sire of the servo. The throttle was at the outtermost hole. What gives. I am in buisness now.
NY
I would only trust that as long as it takes to get a real replacment, if the connector rod every binds up there's a decent chance to solder joint will break.
TN
I doubt the servo could break silver solder. This is real bizzare that I had to do this. many other planes, never had to worry about over travel on throttle servo.
