Dual batt/switch setup on one Rx?
Reply
Old 05-12-2003, 06:38 PM
ShoestringRacer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual batt/switch setup on one Rx?
I just read the latest issue of RCM the GP 300s PW Extra review and he used 2 batts and switches with one Rx? How do the batts plug into the Rx? isnt there only one battery port? I would like to do this set up on my Extra when I get it.
I am using JR 662 with R700 Rx. Thanks
ShoestringRacer is offline
Old 05-12-2003, 08:34 PM
JohnMac
JohnMac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual Batteries
Ideally just use a spare Rx socket. If you do not have a spare you can use a Y lead into a second socket such as throttle.
Regards,
John.
JohnMac is offline
Old 05-13-2003, 03:51 AM
airframe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual batteries
What I'm wondering about is if one battery fails wouldn't the other battery voltage fall also because it would try to equalize the voltage.
Mike
airframe is offline
Old 05-13-2003, 03:56 PM
JohnMac
JohnMac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Twin Batteries
Airframe,
this is possible but a short circuit in a switch is a more immediate problem. Either way diodes can be placed in the circuit to prevent any such action. Diodes will loose .5 - 1v so you need to use 5 cell batteries. This is exactly what I do on any model that can carry an extra battery. Since lots of my models seem to need nose weight its not much of a loss. You don't get much current out of lead!
Regards,
John.
JohnMac is offline
Old 06-15-2003, 03:00 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Both Red and I have a picture and description on how to do this.
Geistware is offline
Old 06-15-2003, 07:23 AM
golf_lake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John the voltage drop through a silicone diode is exactly .6 of a volt.
The diode also needs to be rated at or above the max current you are likely to draw.
golf_lake is offline
Old 06-15-2003, 01:54 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Typically a cell will fail shorted or open.
If you have a 5 cell pack, a shorted cell will give you the equivalent of a 4 cell pack. A cell failing open will allow the other pack to fly the plane.
