voltwatch question
Reply
Old 05-12-2003, 11:23 PM
PMJ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default voltwatch question
i was reading the description on towerhobbies.com about it and it had this in the comments: "ADDITONAL NOTE: This is for 4.8V NiCd packs only! NO NiMH!" exactly how bad is it to use a NiMH pack? will it still read correct or would it be all messed up?
PMJ is offline
Old 05-12-2003, 11:36 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There's no reason why it shouldn't work on a 4.8V NiMH. Those Tower comments aren't always correct. I've had a few of them corrected by Tower for technical and other errors.
rajul is offline
Old 05-13-2003, 01:58 AM
DMcQuinn
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It should work OK with either NiCd or NiMh. But only 4-cell packs. It will not work with a 6.0 volt pack. There are other similar products that work with 6.0 volt packs.
I have a voltwatch and it works great.
DMcQuinn is offline
Old 05-22-2003, 04:06 AM
Devo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The reason the Voltwatch is not recommended for NiMh batteries is because of the way they discharge at the end of a cycle. A NiCd tends to taper off at the end of a charge, whereas a NiMh battery drops off much more rapidly. So, if you have a Voltwatch on a NiMh battery it may show a good charge when you take off, giving you a false sense of security even though it is near the end of it's charge. Then you'll be flying along all happy and suddenly your battery goes dead.
Devo is offline
Old 06-15-2003, 02:49 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always thought it was because my packs were that much better. Thanks for the input.
Geistware is offline
