3 Rates on 10C?
Old 07-02-2008, 01:29 PM
hilleyja
Default 3 Rates on 10C?
Radio South provides a service to change out the 2-position elevator, airlon, and rudder rate switches for 3-position switches and the 9C already has the built in circuitry and programming to support these. Is this also true with the 10C?
Old 07-02-2008, 01:48 PM
hilleyja
Default RE: 3 Rates on 10C?
This was a technical question for Futaba support personnel and originally placed in the Futaba support forum why was it moved to the general area?
Let me refraise the question:
If you wire in a 3-position switch (there are three connectors on the board for each; one is not used in the original configuration) in place of the 2-position airlon, rudder, or elevator rate switch the programming in the 9C detects the availability of the three positions and makes their assignment available during programming. I suspect this is the case because of the 9C's ability to re-assign switches to any radio function. Example: I can program switch 'C' to act as the rate switch for all three axis, making 3 rates available instead of 2 (LOW, HIGH, 3D).
Ques: Does the 10C also also support this alternative configuration (each 2-position switch is connected to 2 connectors on the motherboard but 3 connectors are available) and functionality (programming recognizes additional switch position and makes 3 choices available for rate assignments)?
Old 07-02-2008, 03:36 PM
BarracudaHockey
BarracudaHockey's Avatar
This is a duplicate of the post in the Futaba forum, which is still there.
Old 07-02-2008, 06:03 PM
My Feedback: (17)
8178's Avatar
Switches G and C are three position on the 9C super. I use switch C for my triple rates because it is located in a convenient position. The 10C appears to have the same switches.
