servo swapping
Reply
Old 05-14-2003, 02:38 PM
SchoolRoomSpads
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo swapping
If wired correctly, can I use a futaba servo with an airtronics rx? Does the negative/positive shift effect servos or just tx and rx? Thanks!
Tommy
SchoolRoomSpads is offline
Old 05-15-2003, 04:08 AM
strato911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes - Futaba servos can be used with airtronics if the ends are re-wired.
No - the shift issue does not affect servos, only Rx / Tx compatibility. However, not all servos turn in the same direction for the same signal.
strato911 is offline
Old 05-15-2003, 03:04 PM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, the servos have different color wires for each. Make sure you are soldering the right leads on the right wires.
FLYBOY is offline
