Reversing a Servo
Reply
Old 05-14-2003, 08:51 PM
Malc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Reversing a Servo
Can anyone tell me how I can reverse a servo without using my transmitter?
Malc is offline
Old 05-14-2003, 08:59 PM
Tech-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Reversing Servos
It is very straight forward. When you open up your servo you will see the potentiometer. Reverse the two outer wires but leave the center wire alone. Next, reverse the wires that are soldered to the motor and you are done. This is easier on some servos than others. Thanks!
ServoCity
Tech-RCU is offline
Old 05-15-2003, 08:19 PM
CurtD
CurtD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On many (if not most) modern servos wires are no longer used to the motor (they're a source of failure). The servo is constructed so that the motor and its terminals are soldered directly to the servo controller board. I don't think I would attempt to reverse that type of servo.
CurtD is offline
Old 05-15-2003, 10:59 PM
strato911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They require a bit more caution, but are not much more difficult.
Cut the traces leading to the motor, and solder two jumper wires across them. The same for the potentiometer if it's soldered directly to the circuit board.
strato911 is offline
Old 05-15-2003, 11:24 PM
iflyj3
My Feedback: (7)
iflyj3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the Futaba 3004, I unsoldered the motor from the board and turned the motor 180 degrees. Reversed the outer pot leads and resoldered the motor.
Dan
iflyj3 is offline
Old 05-15-2003, 11:32 PM
strato911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That'll work too - if the design allows it.
Old 05-16-2003, 06:09 AM
Malc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cheers Guys - will get the soldering iron out!!!!!!!!!!!!
Malc
Malc is offline
Old 05-16-2003, 09:48 AM
Dazzler_BE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Offcourse, some may not want to torture there servo.
Instead, you can build a servo reverser, which is't any bigger than a post stamp. Check it out here:
http://www.cliftech.com/html/reverser.html
Dazzler_BE is offline
