Need info on servo hookup, no radio?!?
Reply
Old 05-15-2003, 01:40 AM
Zomie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need info on servo hookup, no radio?!?
Well, I am working on designing a robotic hand for a school thing, I can do it with the servo's I got now but, I only got a 2 channel radio, and well with 4 servos its a bit hard.
How do I do the wiring and what is required just to wire the servo's directly to a switch, I don't need the radio.
I am not sure exactally how these three wires going about doing things, Thanks for any help please remember if this is a stupid question I am new here
Zomie is offline
Old 05-15-2003, 11:29 PM
strato911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No question is stupid, unless you don't ask it.
You can't just wire servos directly to a switch. The three wires are:
- power (4.0 - 6.0 Volts)
- ground
- signal (series of short 1 - 2 millisecond pulses representing the desired servo position).
In order to control servos without a transmitter and reciever, you will require a servo tester like those shown below (all clickable links), or some other electronics to generate the required signals. A 1.5ms pulse represents center on modern servos. The first one shown links to schematics to make your own.
strato911 is offline
Old 05-15-2003, 11:52 PM
Zomie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks alot that helps so much, Thanks Alot!
Zomie is offline
Old 06-13-2003, 07:39 PM
pave-low
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.robotstore.com/catalog/list.asp?cid=17
http://www.ferrettronics.com/product639.shtml
http://www.rotomotion.com/prd_REV2.4.5DOFK.html
There are other sources out there as well for serial to servo circuits with Windows apps and APIs to get you started.
There was a good/simple one I came across last fall that wasn't very expensive. I will try to dig it up.
pave-low is offline
Old 06-14-2003, 07:26 PM
mikeatrpi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can build your own PWM driver using a 555 timer and a couple of resistors, caps and a potentiometer. You can make it variable between 1 and 2ms.
A second solution is a microcontroller- check out Atmel AtMega8535 or similar. The 8535 gives you four channels for PWM output.
mikeatrpi is offline
Old 01-20-2004, 10:59 PM
spyder0069
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Need info on servo hookup, no radio?!?
If your getting started in robotics get yourself a BASIC STAMP microcontroller. They can directly drive a servo and many other robotics projects and are easy to start with. Lots of information on them. Then when your ready to move up go with PIC microcontrollers. Visit this website and join their forum. They are a dedicated group to your interests.
http://www.seattlerobotics.org
spyder0069 is offline
