servo lube
Old 07-20-2008, 12:32 PM
LShaver1
Default servo lube
Its been 20 years the last time I rebuilt a servo..... just orderd parts for 8101 and 4721's
What is the standard gear lube used today if any or what do you use?
TIA
LShaver1
Old 07-20-2008, 01:13 PM
jetpack
jetpack's Avatar
Default RE: servo lube
I have used the clear silicone grease that Team Associated recommends for their differential grease. You can find small, toothpaste tube type bottles in the RC Car sections. They also make a black grease in the same size bottle so be aware.
Old 07-20-2008, 02:48 PM
Flypaper 2
I use white lithium grease
Old 07-20-2008, 04:41 PM
onewasp
Tamiya Ceramic Grease______from your local Hobby Shop. TAM87025 by Tamiya America, Inc 10 gram tube about $6.00. That amount should take you to the end of ____well, about everything.
Use sparingly, you need very little to do a good job.
Works equally well on nylon, metal or other plastics.
Old 07-21-2008, 04:08 AM
A.T.
Servo - Troubleshooting problems (Inc DIY Servo Gear Lube) : Hitec answers
"Q. What is servo grease?
Use only silicon based servo grease when replacing servo gears. Using other type of grease not intended for servo gears may produce a gas when used in sealed cases which may coat a nasty film on the motor brush that could stop the servos operation. Hitec recommends our product #58450, servo grease."
Further information under sub section "Servo - alterations, calculators, databases, leads, repairs, convert to an ESC or winch & FAQ." at
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
Old 07-21-2008, 08:39 AM
BarracudaHockey
BarracudaHockey's Avatar
Silcon dielectric grease, get it at any autoparts store in the electrical section.
Old 07-21-2008, 01:45 PM
Four Stroker
BaracudaHockey wins again.
Old 07-24-2008, 04:21 PM
dirtybird
I got some Hitec servo grease from servocity.com for $3.95
