Help JR 12x
PA
RE: Help JR 12x
Barracuda is correct. Shutdown the radio. Hold the bind button in. Turn the radio on while holding in the bind button. The radio defaults to the model select. Press in the scroll wheel to access the model. Press it again to call up a list of available memory channels. You are there...
Have a great day!
Smacka
Have a great day!
Smacka
My Feedback: (55)
RE: Help JR 12x
According to the JR 12X manual page A4, you hold the Enter button (not the bind button) and turn on the TX while keeping the Enter button pressed. This puts you into the 'System Mode' where you can then select 84. 'Model Sel' and you should be off to the races. If you select 'Model Sel' and it takes you to model copy then you have a TX problem. This is identical to the 9303.
Howard
Howard
My Feedback: (31)
RE: Help JR 12x
Step 1. Hold the ENT button
Step 2. Turn on the radio
Step 3. Select 84 if it didn't default to 84, it should be
Step 4. Press the roller one time to get to the next page
Step 5. Should high light "Select"
IF you get the word "Copy" highlighted press the roller once with the word and the display will change to "Select"
Step 6. Roll the roller to the right one click.
Step 7. "Model" will be highlighted
Step 8. Press the roller one time which should bring up a list of airplanes or blank spaces
Step 9. Roll the roller right/left untill correct model is highlighted (or a blank number for a model not assigned
Step 10. Press the roller once, this will "Load" the model's memory
Step 11. Turn the radio off and back on normally and the new model will be displayed.
Now turn the radio on with the ENT held down and roll the roller one time to get to the "Model Name" roll the roller 3 clicks to the right which will bring the cursor to the first space between the < > symbyols
Press the roller to access the alpha/numeric page then roll the roller to where the cursor is under the letter/number/symbol that you want. Repete for the next space untill you name that plane.
HTH
Tim
HTH
Tim
My Feedback: (41)
RE: Help JR 12x
ORIGINAL: Mastertech
HTH
Tim
HTH
Tim
The "select" "copy" function change is not really that intuitive and I kind of futzed around with it on my X9303 before I figured it out. But it IS in the manual had I read it a bit more closely before starting....
The 12X programming is very similar to the X9303 and I can't comment on the 10X as I came over to the X9303 from a Futaba...
