How do you set up flaperons an the JR X9303?
WI
I want to set up flaperons on one of my planes on a JR X9303 and I don't know the steps to go through to do it. I'm not using flight modes and I'm not sure if I have to. Can someone help on the setup?
RE: How do you set up flaperons an the JR X9303?
You do not need to use Flight Modes to use Flaperons. Think of Flight Modes as 3 separate model memories for each model memory in your Tx. If you go to a given Model Memory, for example, there are dozens of parameters you can change to configure your model. They include Subtrim, ATV, Programmable Mixers, Switch Assignments, Dual Rates/Expo, etc. Flight Modes allow you to configure up to 3 separate conditions, each with all the parameters included in the model memory, and you can use a 3 position switch to quickly change from one condition (Flight Mode) to the next, while you are flying. You could have a Takeoff mode, a 3D mode/Aerobatic mode, and a Landing mode, for example.
ORIGINAL: Birman
My Feedback: (89)
Hook up 2 Servo Aileron non Flaperon
#1. Go to DEVICE SELECT and rotate the
roller until you are under AUX2 (on the bottom of the screen), Press the roller and INH AUX2.
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under AILE, Press the roller and select AUX2.
NOTE: Connect Right Aileron to Aileron and Left Aileron to Aux2.
Try this ...do you need flaperons..?
Codimasta
AMA 11269
Codimasta
AMA 11269
