range of 27 mhz Am radio
NL, CANADA
Hi,
just purchased a sanibel sailboat with a 27 mhz am radio. what is the effevtive range of AM? I currently fly planes on 72 mhz and know that the range of transmission is quite far, but have never used am transmission radios. your input please.
Ed
Ed
RE: range of 27 mhz Am radio
I do not think the range is restricted by whether or not you have an AM radio. There may be differences in overall range, but I flew my aircraft out to the same distances, with an AM radio, that I fly my recent planes with an FM radio. I think the output of the Tx you are using would have more of an effect on Range.
Be aware that I have seen at least two aircraft, in the past two weeks, with radios on 27Mhz Ch08.
NL, CANADA
I guess the most effective way to ensure range is to do a range check with the radio I am using. I would not want to sail my $400 sailboat out of range and out to sea![]
Ed
Ed
Range is not determined by whether AM or FM but by two things; power output of transmitter and sensitivity of the receiver. Since most of the RC units in the USA are limited by law in output power (nearly all are set at this max level) the prime factor is the sensitivity of the receiver. This can vary greatly plus quality of the design can vary (some are not tolerant of noise) and in general this is proportional to their price but not always. Many of the cheaper units have poor range and are not very selective when it comes to noise rejection. The only way to know for sure is to do some range checks and find out what the limits are on your particular set up.
ORIGINAL: sleded42 Hi, just purchased a sanibel sailboat with a 27 mhz am radio. what is the effevtive range of AM? I currently fly planes on 72 mhz and know that the range of transmission is quite far, but have never used am transmission radios. your input please. Ed
In need, also refer to sub sections "Receiver - FAQ, guides and aids to best reception." and "Boats, Yachts, Submarines, Warship Combat and Nautical reviews"
Regards
Alan T.
