heat and radio equipment?
My Feedback: (12)
OH
I am thinking of moving my planes and equipment out to my garage/barn that gets pretty hot in the summer. will the excess heat harm my planes and radio equipment?
thanks
Jeff
thanks
Jeff
RE: heat and radio equipment?
It can. Any chemical processes will be speeded up and some plastics will suffer. Wood will lose a lot of moisture and may change dimensionally. That being said, I store my stuff in an uninsulated garage here in Florida with not a lot of problems. I think some of my Monocote and other plastic coverings have shown a bit of deterioration and some of my adhesives have had an accelerated "end of life" date but in the main, all is okay.
ORIGINAL: jjoos99
thanks
Jeff
thanks
Jeff
In the past, some receivers have been heat sensitive.
ORIGINAL: BuschBarber
WA
I have had balsa wings warp from being stored in southern calif heat, and I've had monokote come unglued. Not every wing every time, but it has happened, and it was easily fixed with an iron or heat gun.
Electronics shouldn't have an issue with a hot room unless they have a weak spot like a cold solder joint, etc that would eventually fail anyway.
To be honest, I'd be more concerned about mice and insects.
ORIGINAL: Silent-AV8R
But not from sitting in storage. The situations I know about happened when an assembled plane was left out in extreme heat exposed to full sunlight on asphalt, etc. I store all my stuff in an uninsulated garage. South facing door (no insulation) it gets pretty warm during the summer. Never seen an issue with it.
Ditto that. The only problem other than an occasional surface warp I have ever had associated with heat is, I had the screen on my Fut 8UAF get very dark due to being left exposed in direct sun over an extended period of time. Now after flying I make sure it's replacement which was a gift from a friend is now kept in it's case when not in use.
ORIGINAL: jjoos99
thanks
Jeff
thanks
Jeff
corrected also as I understand it the receivers would fail if they got to hot while setting in the sun or in a hot vehicle but once they cooled off they would
always work fine. I dont think there were ever any reports of receivers failing in flight due to heat.
