JR 662 & Delta/Elevon set-up help please.
Reply
Old 05-24-2003, 01:26 PM
Bad Driver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR 662 & Delta/Elevon set-up help please.
Hi,
Could anyone please tell me how to connect the servos to my JR R700 r.x. channels for correct Delta Wing/Elevon operation. T.x. is a JR 662.
(When I bought this transmitter here in England last year it was supplied with a U.S. XP652 manual which has different programming switches and no mention of channel connections for Delta wing )
Very many thanks !
B.D.
Bad Driver is offline
Old 05-24-2003, 02:28 PM
Peter Khor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pg 25 of the 652/662 manual, follow plug instructions for V-tail, mess around with the servo reversing manual untill it's right.
Peter Khor is offline
Old 05-25-2003, 11:36 AM
Bad Driver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Peter,
Thanks for the reply but I'm afraid that's not the correct connections as only one servos moves.
I've tried one servo on Elevator and one servo on Aileron channels and with the Delta mix on this seems to work (not installed in the plane yet tho). But I'm not sure which left/right servo should go to which channel without trying all the reversing, trims, etc.
Hey, it's an EPP glider - I'll just throw it off a cliff and find out, it can only bounce
B.D.
Old 05-25-2003, 01:39 PM
Ed_Moorman
Ed_Moorman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Elevons
I haven't checked the manual, but on all the JR's I have owned, you have to go to the System Set-up Menu and set an Elevon wing type. This is the menu you get to by turning the Tx off, holding down the Up & Down buttons and turning it on. Then you go to wing type and select Elevon or Delta.
Ed_Moorman is offline
Old 05-25-2003, 02:50 PM
Peter Khor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just to clarify:
* go to system menu
* enable DLT wing mode
* plug servos to Elv and Ail (as per V-tail instructions, that's the only wing type that they tell you how to plug the servos).
* cycle power switch
* go to servo reversing menu
* try out different Elv/Ail Norm/Rev untill you get the correct stick movement; ie:
* pull stick both elevons move up, push stick both down
* right stick R elevon up, L down; left stick L elevon up R down
You have to adjust the Norm/Rev as servo placement is different for each a/c (ie, servo is on top or below, facing forward or backwards, etc)
Old 05-27-2003, 08:18 AM
Bad Driver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Many thanks Peter !
Seem to have got it all working o.k. now.
B.D.
