11.1V LiPo for TX?
OR
11.1V LiPo for TX?
Anyone know if I can use a 11.1V 3 cell LiPo for my 9C tx? I've already been through the "we cannot recommend or concur with this" blah blah from Futaba. Thanks in advance.
CO
RE: 11.1V LiPo for TX?
works fine. I've used them for a few years. Just make sure you balance the cells occassionally. I didn't and had a fie even though I was using good charger (Triton) and it was set up correctly. I think one cell got low and the charger over charged the other cells.
My Feedback: (15)
I have used several now for over a year in my 9CAPs: one from www.2dogrc.com and two from www.unitedhobbies.com.
Kurt
Kurt
Yup, you can do it, and sure you may never have a problem. But be aware that if you're using a standard 72Mhz module, that there is no regulator, it uses the battery voltage straight in. With a good 1.5V higher than a fully charged Nixx battery, you run a higher risk of failure of the output stage, especially if you run it any length of time with the antenna collapsed. I'd get a pack of Eneloops from Sanyo, the self discharge is almost as low as a lipo, 2000mAh runs a loooong time, especially if you use a fasst module, you'd get close to 12Hr. with 2000mAh.
Pete
Pete
OR
Well, I finally got word straight from Futaba that their radios are rated to 14 volts input. So, no worries about an 11.1V LiPo even at peak charge.
Now, I do know that JR and Spektrum run 11V max.
ORIGINAL: mtwister
You want a Lipo in your tx
DO IT
If things go wrong - you have no one to blame but yourself
The manufacturer says don't do it
there is no really good reason to do it
except you want to do it
so do it.
DO IT
so do it.
guys
your forgetting one important thing
in order to use a LIPO insted of a NIMH or NICD you need to change the setting in the radio!!!!
theese settings are accesable via the "service menue" only!!!!!!
1. need to get into the service menu
2. chnage the type of batt use to LIPO
3. change the "low batt" alarm setting compatible to a lipo standard 3.1v per cell
4. DO NOT CHARGE wika a wall charger only with a LIPO charger!!!
i'm suer u can find threads about the service menu for Futaba
i'm a JR guy myself
i'm a JR guy myself
OR
ORIGINAL: Rodney
Note: your LiPo's are at 12.6 volts at full charge, not 11.1 volts.
ORIGINAL: mtwister
Well, that's why I say that at 11.1 they're fine, since Futaba says the radio is good UP TO 14V.
OR
ORIGINAL: dick Hanson
DO IT
so do it.
DO IT
so do it.
I flew all day Sunday with my LiPo installed in the radio. I had the radio on a total of 4.4 hours and the battery was still at 10.9 volts. Normally I would have had to charge my radio twice with that much flying. So, I'm very happy with the results. For those of you that offered up usefull suggestions, thank you. For those of you that are just bitter and sore, well, enjoy it
Yes that would be helpful to many. I wouldn't mind trying it. I have too many unused lipo's here that need a job like that. Thanks for the update on it. Glad to hear it is working well for you.
Happy landings,
Kevin
Happy landings,
Kevin
My Feedback: (15)
ORIGINAL: mtwister
Excellent, now that I have your blessing I guess I just might. Oh and by the way, I got word from Futaba that it's fine, in fact there's a setting in the radio to change to a LiPo. So lighten up. Don't be a jerk just because you can, that makes people hate you, and who wants that?
DO IT
so do it.
DO IT
so do it.
mtwister, I'm 100% with you! I like your style.
Kurt Bozarth
DO IT
so do it.
DO IT
so do it.
ORIGINAL: mtwister
This excludes the transmitters like the 12Z and 14MZ that are designed to use a lithium battery. However, both of those are 7.4 volt packs (2S).
The 4PK actually has a HIGH voltage warning in it. It is made for a 5-cell NiMH or NiCad pack and will give an alarm at start up if you exceed 8 volts. A 2S lipo would be at 8.4 fully charged.
mtwister,
Not sure where or "who" you are getting your information from. But it is INCORRECT. There is no option in ANY of the Futaba transmitter service menus to change battery type.
Futaba does not now, nor ever has recommended using LiPo batteries in their transmitters. Doing so will void any warranty if there is any damage to the transmitter.
If you have a problem with your transmitter and send it into the service center for repair, any problems that are due to the type of battery you have used, your warranty is no longer good.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
[/quote]
[/quote]
Sincerely,
Krysta
[email protected]
[/quote]
[/quote]
All I have owned is futaba radios for air use and to this day I have not seen or heard of any info that they pass along. Why is this? Your on top of things that "will vod your warranty" but thats it. Why not get one of those Futaba guy's (the ones we can't hear from" to come here and explain some of these things? They obviously don't fill you moderators in either or reps as your called. You's give us the same info that comes with our radios. What exactly do you's know that we don't when we buy our radio's? Sounds like they just make you study their manuals and repeat that info to us. It is getting fuzzy around here. I have about 4000.00 wrapped up in Futaba radios and it seems like I am wasting my funds....no? I pondered may systems when I bought my 12FG and thought why not stay with what I know......seems like I should have chosen a company with knowledge of their product better.
Kevin
Kevin
OR
ORIGINAL: Krysta
mtwister,
Sincerely,
Krysta
[email protected]
mtwister,
Sincerely,
Krysta
[email protected]
[/quote]
[/quote]
Krysta, while I thank you for the verbal "warning", I have to let you know I'm far out of warranty so I'm not at all concerned with this. Unlike many others who venture outside the box, I fully understand that I'm liable for my own actions.
Also, I never mentioned that they (Futaba) recommend using a LiPo, but again, thank you.
Where I got my information, is from the horses mouth itself For those of us that are able to actually read a manual, and a schematic, it's plain as the daylight itself. Again, thank you
Kevin,
I am not sure how much more information you are wanting me to give. As I work in the Futaba Service Center, I know and have access to the service menu's of each Futaba transmitter. There are no transmitters that have the option of changing battery type in any of them.
We get questions from the public, and if we do not know the answer, we ask Futaba Japan. We have contacted them more than a few times on this topic, and their answer to the use of Lipo's is that they do not recommend it as they may cause damage to the transmitter.
We did not feel that we needed more specifics than that.
If you want to use Lipo's, you are more than welcome to use them. But again, any damage to your transmitter caused by these will void the warranty.
Krysta
[email protected]
Krysta
[email protected]
OR
ORIGINAL: Krysta
Kevin,
Krysta
[email protected]
Kevin,
Krysta
[email protected]
Thank you for your approval, now I can sleep tonight LOL...
ORIGINAL: Krysta
Kevin,
Krysta
[email protected]
Kevin,
Krysta
[email protected]
If anything can be learned for Futaba's sake it is to get a better communication link to their customers. I and many others would be satisfied with that I am sure.
kevin
