Servo Extensions or Extending the Servo Wires
RE: Servo Extensions or Extending the Servo Wires
OK, All you guys that like to solder on your extensions. What is the best way to twist the bare wire ends before soldering to avoid ugly looking lumps under your shrink tubing? Would also like to minimize the length of the stripped portions to be soldered.......RJ
To the OP..I was in the same dilema. I bought a 33% edge540 and started building away. Read as much as possible and read some more. I came to the conclusion that fiber optic servo extensions were the cheapest insurance for my throttle servo and the vibrations it will encounter. I found the write up on them here in the Edge540 build and review by Marc Vigod. http://www.rcuniverse.com/magazine/a...article_id=474 He used these in his build and from the sounds of it had good luck. I went to this site http://www.forgues-research.com/ and ordered up a pair. I am now finally installing them. They are nice! It uses the ignition battery or another seperate battery for power and fiber optic trasmition of the signal eliminating the possibility of rf noise heading back to the rx via servo ext. If you use a seperate small pack like a 5 cell nimh then all that power is for your throttle servo only. Just another option to ponder.
Kevin
Kevin
I haven't heard a bunch of horror stories about servo extensions gone bad; ever. But, I can see where continuous plugging and unplugging would be their undoing. Its a pain but for my ailerons I've been dental-flossing the connection as an added precaution in case I need to ever pull it out but just can't imagine a benefit from soldering.
I am interested in how you would shove the ends of two trimmed wires together, twist, and get them to stay put while soldering. I've tried with intermittent success and when it worked out I could slide a piece of heatshrink over. But most of the time I've regretted the effort.
Regards,
Clay
Regards,
Clay
#31
ORIGINAL: RJConnet
#32
Just got it hooked up and it works great in bench tests. Will test it thoroughly pre maiden once I can get it out and fired up.
Kevin
Kevin
#33
With fine stranded wire as used in servos I use whats referred to as a line splice, strip about 3/8th inch then align the end of each wire so they're just short of the insulation, and gently twist them, you can get them real smooth with a little practice. If you do this or the way Rodney suggested just make sure you have a clamp to hold the wire while soldering. Two wooden spring type clothes pins glued to a piece of wood for a base is an invaluable tool
Good luck,
Pete
Good luck,
Pete
#36
AZ
Maybe things have changed in the last 50 years but when I was working on the LO Spacecraft NASA would not let us use soldered connections due to the fact the joint would have to be destroyed to inspect it. I use gold plated good quality extenders.
In emergency I have used spliced in extenders. I found if I did a neat parallel solder joint the heat shrink would sometimes slide off leaving the joint exposed. So I just twist them together and solder. That ugly lump will hold the heat shrink in place.
