Radio problem.. any Ideas?
Reply
Old 05-28-2003, 01:52 AM
hyperviper89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Radio problem.. any Ideas?
Ok everyone, I just lost a U-CAN-DO today, here is what happened...
I was flying and made a turn toward me, I went to turn more and I noticed that I had very little aileron to the right(next to nothing). I tried left and it worked fine(just like rudder and everything else) so I went ahead and pulled it hard away to make sure if it went it was going to be out of the pits. I slowly got the plane to roll very slowly to the right to level it off. I was about 30 feet in the air and then I lost all control and the plane hit at a -30 angle. It acted like a battery problem so before I moved the plane I took my tester to the crash site. I checked over everything and didn't find a problem. The plane worked fine after the crash. I am not useing PCM and the RX has about 10 flights(all i got from the plane) and I am using the Futaba 9c. So now I really have no clue whats wrong. I have had my share of bad luck lately. I am thinking that I am just going to quite the hobby for month or so, I just have no planes now and seems like everyone i get (even if its free) crashes within a month. I might just not fly anymore until I go giant scale.... but back to the radio question, any ideas????
hyperviper89 is offline
Old 05-28-2003, 03:51 AM
searcher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Radio Problems
Hello Conrad,
Dont get too discouraged.
I am curious if you were using digital servos with a standard FM receiver?
I had JR 8411 digital servos in my UCANDO and was using a hitec FM receiver and a Hitec Eclipse 7 radio. The digital servos seem to hum and buzz all the time, which they tend to do in my other planes as well. I noticed that the servos glitched occasionally. On the fifth flight I lost left aileron control, it went to full extension in the up position. I compensated by applying full right stick making the right aileron go to the fully up position. I guided it back using rudder and elevator and she did the most beautiful harrier landing! Anyways, I never could figure out the glitching. I swapped the Hitec rcvr out for a JR 955 and a JR10X xmtr and all was well. The Hitec was put into another bird with standard servos and it was fine there.
Can anyone tell me if there is an issue with using digital servos with a non PCM receiver? Perhaps more specifically JR digitals; I've used Hitec digital servos with a standard rcvr and had no issue.
searcher is offline
Old 05-28-2003, 12:33 PM
hyperviper89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats lucky.... I was planning on the same, but when I lost complete control of the plane there was no hope. :stupid:
Old 05-28-2003, 12:39 PM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It sure sounds like a battery failure to me! I'd suggest you cycle the battery to validate it's condition. You might take look at all the electrical connectors and switch as well, maybe you have broken wire, bad or intermittent switch.
mglavin is offline
Old 05-28-2003, 01:48 PM
hyperviper89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Battery was my initial thought. I have just took it off the charge and before I flew it was just under 7 volts. After the crash it was down to about 6.6 volts. The battery has only about 10 flights on it as I put a new RX and battery in this plane. The battery is a 6v NIMH 1650 from radicalrc. The battery is fine(radicalrc sure has nice products) and all other electrics were fine. Is their anything with RF that might cause this? Thanks
Old 05-30-2003, 06:49 AM
Andrew_S
My Feedback: (12)
Andrew_S's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the problem starts with the letter "F" and ends with "a"..... :drowning:
Andrew_S is offline
Old 05-31-2003, 02:03 AM
BalsaOvercast
My Feedback: (16)
BalsaOvercast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's my 2 cents...
We've had 3 UCD's crash at our field lately. All were using different radio and servo combinations, and all had good battery packs.
The common thread for them all was that they were all flown TOO FAST! The UCD is a fluttering beast, and you'll strip an aileron servo out faster than you can say "Oh **it!" If those broken teeth get stuck in the geartrain, you'll have a deflected aileron right quick, and no input will save her.
Throttle management is the key, or at least, that's what I've seen at my field.
BalsaOvercast is offline
Old 05-31-2003, 03:11 AM
David Cutler
David Cutler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could it be that the switch was faulty, or simply switched off with the vibration?
-David C.
David Cutler is offline
Old 05-31-2003, 03:47 AM
hyperviper89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I checked the switch too...it's one of those nice MPI ones
Old 05-31-2003, 05:34 AM
plumberdeluxe
My Feedback: (208)
plumberdeluxe's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You'd be foolish to quit flying without trying a nice radio like a jr or airtronics. Sell your Fubar, I mean Futaba
plumberdeluxe is offline
Old 05-31-2003, 11:48 AM
gjhinshaw
My Feedback: (303)
gjhinshaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All of these sound like it would be it, I can't beleaxe that it was none of the above. But .... One other thing that may have happened is that you or someone close to you had a CELL PHONE on them. There has been a NEW study on the interferance with cell phones and radio's. They can still cross signal's and you can lose your plane. I thought I was having radio problems. So after reading the clip I left the phone in the car and had no more problems. They say to keep cell phones about 100 to 200 feet away from the flight line. You can take this for what its worth, but it worked for me...... KEEP FLYING
gjhinshaw is offline
Old 05-31-2003, 12:50 PM
david a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I have a suggestion. Get a basic four or six channel non-computer radio then go fly.
david a is offline
Old 05-31-2003, 04:45 PM
Andrew_S
My Feedback: (12)
Andrew_S's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Amen plumberdeluxe....HAHAHAHAHA
Andrew_S is offline
Old 06-01-2003, 04:41 AM
hyperviper89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I answer calls on my cell while flying and never get hits... I don't think that was the problem here
Old 06-01-2003, 09:07 AM
spasmatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check to see if your antenna in screwed tightly to the post on your transmitter. This accident sounds just like what happened to me while flying my giant stinger. The control became erratic and finally a steep angle crash. Everything checked out and I was totally puzzled until I started to retract my antenna and found it was loose. The radio I was using is a Futuba 6XAS.
spasmatic is offline
Old 06-01-2003, 06:01 PM
N1EDM-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm wondering if it could be that the ailerons had something jamming them (or the servo itself), such that they could only move in one direction and not the other?
If servos are buzzing, then something is impeding their progress, i'e', something is rubbing, misaligned, or too tight.
We're making the assumption that the ailerons were in perfect condition, and they might not have been. The radio itself may have been perfect. It could have been that you had a linkage or hinge problem with the control surface.
I'm not saying that it is, I'm just saying that it could be a possible culprit to look into.
I'm just adding my 'devil's advocate' $.02
Bob
N1EDM-RCU is offline
Old 06-02-2003, 01:18 AM
hyperviper89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that was my first thought, but I checked them all and they were fine
Old 06-02-2003, 10:43 AM
Andrew_S
My Feedback: (12)
Andrew_S's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Simple.............Everything checks out a-ok, no mechanical problems anywhere only leaves 1 more thing.......Pilot error.....Andrew
Andrew_S is offline
Old 06-02-2003, 11:25 PM
hyperviper89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL.. yeah right Andrew... thanks for the tip :stupid: ... Did you see the crash? That was no error from a high gentle decent into the ground...
