SPEKTRUM RECEIVERS LOSE BINDING???
Old 11-18-2008, 11:15 AM
darticus
Default SPEKTRUM RECEIVERS LOSE BINDING???
Can anyone help with this. I find that the AR6100 receivers lose their binding on occasions but it seems to be something else causing this. I was going to return the receiver but found the next one did the same thing. So I rebinded it and its ok! Than a day later its either ok or it loses its bind. WHAT IS CAUSING THIS??? Is it a drain from the motor or servos or ESC causing the memory to be lost??? Maybe its the 45 degree temperature storage??? Thanks Ron
Old 11-18-2008, 11:59 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: SPEKTRUM RECEIVERS LOSE BINDING???
Are they actually loosing their binding or are they flashing?
Most problems I've seen truly involving "lost binding" are when the transmitter is placed in such a manner that causes the bind button to be pushed in, or a BEC is hooked to the batt/bind slot that causes a ground to show up on the signal line of the bind port.
Old 11-18-2008, 06:03 PM
airbusdrvr
I was also going to mention accidental depression of the bind button when the transmitter is turned on.
