x9303 dual servos on ail,elev,flaps
Hi, everybody, Iam graduating from 2 servos on 2 channels to 2servos on ailerons, elevators, flaps and, for good measure flaps/elev compensation.
I have followed all manual A sections, but no success[], i am a little upset at myself...
Appreciate the help.....
My Feedback: (55)
RE: x9303 dual servos on ail,elev,flaps
Go to a model memory and reset it so that you know you are beginning from scratch. Device Select 'gear=inh', 'flap = sys', 'aux2 = inh', 'aux3 = inh', 'aux4 = inh'. Wing Type, 'wing = normal', mate 'aile = gear', 'elev = aux2', 'rudd = inh', 'flap = aux3'. From there go to the 'flap page' and program the flaps the way you want and then observe everything working on the 'monitor' page. Just what you asked for. Hope that helps you - the two pages that take some getting use to and thinking about are the 'Device Select' and 'Wing Type' and once they become part of your thinking process then everything should fall in line for you.
Howard
Howard
Thank you, I would have never thought of mating ail to gear.....Isuppose that retractcs could then go on aux 4?
I am going to try your suggestion today.
Good flying.
Good flying.
My Feedback: (12)
CA
fellow flyers, I,m new to the site....looks pretty cool. I,m having trouble with a mini servo for carb, without the pushrod hooked up there is no buzz with radio on..... with push rod hooked up it buzzes, any suggestions.... I,ve spent hours on this.....thanks
ORIGINAL: dave de
My Feedback: (55)
ORIGINAL: dinorc
Good flying.
Good flying.
Howard
