testing 6v system ?
Reply
Old 05-30-2003, 02:54 PM
rkrig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default testing 6v system ?
Anyone know what I can use to test my 6v rx battery under a load? Thanks. Randy
rkrig is offline
Old 05-30-2003, 04:44 PM
strato911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A 30 Ohm resistor will provide approx 200 mA load at 6V. Just make sure it can withstand 2 Watts or more. Then measure with a digital voltmeter. If you want more load, recalculate with your desired load.
Volts / desired Amps = required load
6 V / 0.200 A = 30 Ohm
6 V / 0.300 A = 20 Ohm
________________________
Volts * Amps = Watts
6 V * 0.200 A = 1.2 W
6 V * 0.300 A = 1.8 W
strato911 is offline
Old 06-03-2003, 02:15 PM
i4c
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Loaded Battery Tester
Randy,
This tester has three different loads to check different size battery packs. Reads up to 18vdc.
http://www.i4cproducts.com/battery_tester.htm
Rod
i4c is offline
Old 06-03-2003, 02:31 PM
SMALLFLY-
My Feedback: (19)
SMALLFLY-'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As strato said a 20 dollar volt ohm meter and a resistor in line is all you need. If you want to spend 60 bucks or a little more buy a cycler - dymond recycler/charger is about 99 bucks
SMALLFLY- is offline
