Hitec hs55 reverse action
CO
I need to reverse the movement of an hs55 servo. They say it can't be done but why can't I just switch the hot(red) and ground(black) wire at the plug. Without using the radio reverse feature. I can't change the positionof the servo or horn. This is the F5-E tiger foamie. thanks for any info......
IL
RE: Hitec hs55 reverse action
You can also order one reversed from Servo City for an extra 10 bucks.
http://www.servocity.com/html/hs-55_sub-micro.html
ORIGINAL: Hiflyer001 I need to reverse the movement of an hs55 servo. They say it can't be done but why can't I just switch the hot(red) and ground(black) wire at the plug. Without using the radio reverse feature. I can't change the positionof the servo or horn. This is the F5-E tiger foamie. thanks for any info......
Alan's Hobby, Model & RC FAQ Web Links
for various detailed methods.
Regards
Alan T.
CO
These 2 elevator servos used in the F5 Tiger are imbedded in the foam on a Y connector. I just read where futaba and hitec micros move in opposite directions. If true I could just get a futaba micro....????
