Futaba 6EX 2.4 Question
MA
I was surfing the Tower Hobbies site and noticed they had a Futaba 6EX 2.4 on sale for $189.99 (w/S3001 servos).
Can someone explain the difference between these two radios? Is it just the difference in servos - 3001 v.s. 3004?
I'm interested in a new radio for my second plane (Goldberg Tiger 2).
Futaba 6EX 6-Channel 2.4GHz/4 S3004 Servos: ($259.99)
http://www3.towerhobbies.com/cgi-bin...?&I=LXSFY3&P=0
Futaba 6EX 6-Channel 2.4GHz/4 S3001 Servos: ($189.99)
http://www3.towerhobbies.com/cgi-bin...?&I=LXSFY4&P=0
Charlie
Charlie
RE: Futaba 6EX 2.4 Question
The lower price one is a heli version. All the same software for airplanes and helis in both, just a slightly different switch location layout. Killer price. The 617 RX is $100 right now, so $89 for the TX, chargers, RX pack and 4 servos. Seems killer to me.!!
Switches are physically the same, but the function varies based on whether heli or airplane mode is selected.
S3001 Standard
FUTM0029
Volts Torque Speed
4.8V 33.3 oz-in. 0.28 sec/60°
6.0V 41.6 oz-in. 0.22 sec/60°
Dimensions Weight
1.6 x 0.8 x 1.4 in. 1.6 oz.
S3004 Standard
FUTM0004
Volts Torque Speed
4.8V 44.4 oz-in. 0.23 sec/60°
6.0V 56.9 oz-in. 0.19 sec/60°
Dimensions Weight
1.6 x 0.8 x 1.4 in. 1.3 oz.
Hi, hope you dont mind me stickin my beak in but........ if I were you I`d go for the 7C at least. I bought the 6EX earlier in the year. For a start it has limited model storage. Flap switch is not variable...it`s either on or off. Mainly though, the channel mixing is rubbish. i.e dual servo setup for elevator. It can be done by activating PMX1 AND PMX2 and setting one to -100% and the other to +100%, but you still don`t get the sme throw, and there`s no trimming for the slave channel. Avoid my mistake...louisben
MA
From the Futaba direct support forum - the radios are identical. Only difference is in the battery pack and servos.
http://www.rcuniverse.com/forum/m_8245487/tm.htm
ORIGINAL: chaz5500
There is one physical difference. The heli mode has a smooth detent on the throttle ratchet. The airplane has the usual "click" feel to the throttle.
I bought the heli version due to the low cost. I bent the ratchet detent so it has a bit of "click" feel to it.
Or you can buy them:
http://www.rcuniverse.com/forum/m_8278859/tm.htm
MA
Couldn't resist - pulled the trigger on this deal!
189.99
-20.00 discount
169.99
Shipping was waived on my order too! Sweet! [sm=thumbup.gif]
189.99
-20.00 discount
169.99
ORIGINAL: chaz5500
189.99
-20.00 discount
169.99
189.99
-20.00 discount
169.99
i used it for 2 different gas flyers as well. rock solid, and it's also the system that brought me back to RC. no interference or glitch issues.
