Reversing JR servo
Old 03-21-2002, 04:17 AM
JERRY L
Default Reversing JR servo
I need to revers one of my elevator servos.is a electronic reverer a good way go or can i by one that is mad that way. i am useing JR radio and servos
Old 03-21-2002, 05:15 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
you cant reverse the radio channel?
Old 03-21-2002, 05:40 AM
JERRY L
HI john, i have one servo on ea elevator. i only need to revers one side.
Old 03-21-2002, 06:50 AM
pilotkelowna
Jerry:
Can you move the one of the pushrods to the other side of the servo arm?? Servo reversers run about 30 bucks
Old 03-21-2002, 02:06 PM
JERRY L
Yes, that is the way i have it now. but i have been told that this will cause a problem with the geometry. one moving down and one moving up slightly diffrently will causing a rolling effect when you apply elevator.
Old 03-21-2002, 03:55 PM
pileit1
What transmitter are you using? It's possible , with some transmitters, to mix another channel with the elevator for a dual setup. That way you can reverse the second servo.
Old 03-22-2002, 01:29 AM
JERRY L
My radio is a JR XF631, could i ues v-tail or delta wing mixing to do this?
