Dual 2.4 JR RX - Same plane
Old 01-25-2009, 09:52 PM
dmyers0403
My Feedback: (48)
Default Dual 2.4 JR RX - Same plane
Any reason not to use two 2.4 JR Spektrum RX in same plane. My intent is to convert KMP OV-10 from a single RX located in center pod to a RX in each nacell. Each side will then have seperat RX to simplefly field hookup/assembly and remove multiple long servo leads to center pod etc. (except for nose steering and air/retract hookup)
Old 01-25-2009, 11:46 PM
BuschBarber
Default RE: Dual 2.4 JR RX - Same plane
I have friends who do just what you have described, for the same reasons. It will work fine.
Old 01-25-2009, 11:51 PM
Rcpilot
My Feedback: (78)
Rcpilot's Avatar
Like this?
The remote RX's are mounted wrong in this picture. The antenna are all pointing horizontally. They've since been re-mounted so the antenna are pointing vertical.
Just bind each one. You can bind at the same time or not. Makes no difference. Do your radio setup and re-bind before you fly it.
