At the end of my rope with 8U CCPM! Please help.
OH
Is there anyone out there who can tell me how to get the collective to move the right direction with a Futaba 8U (non-super) using CCPM (EMS) on a Caliber 30? Everything is set up according to the manual and the Futaba website, the cyclic works correctly, but the collective needs to be reversed.
I have asked this question in other threads and nobody can give me an answer. I have tried every suggestion in these threads and on the Futaba FAQs. Nothing works.
OH
Unless I'm missing something, you need a computer radio to do the electronic mixing, so getting a basic radio would be a step backwards.
Anyway, someone may have found a solution; I have to try reversing the pitch curves.
Are you with the minuteman program? I worked with the 390th at Tucson - Titan II... may they rest in peace. Olympic Arena 1982 (SMCC).
MA
I think you either need to reverse the collective, or change the value of the collective in the ccpm setup from positive to negative. Scroll to 0 and see if it will keep going but now negative.
