New Hitec Aurora 9-Channel 2.4Ghz Radio System
#3501
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
I just did a quick search to find that page. I was not sure if those were the only choices available to you. I thought you might be able to search the site and find the proper adapter. I have used Futaba for years, so I am familiar with the Round DIN and the Square connectors on Futaba radios. I still have the Round to Square Trainer Cords. I thought JR/Spektrum were the only radios that required batteries in both the Master and the Slave. It sounds like you have to be careful since the A9 operates at a lower voltage.
#3502
Thanks - will have another look and maybe a trip to the LHS!
ORIGINAL: BuschBarber
#3503
ORIGINAL: Beej Hi to All, I'm really enjoying my Aurora 9 and have well and truly retired my Futaba 6EX. But now I want to do some instructing and I need advice on what cable (if any) will let me use the Aurora 9 as the master and the 6EX (fairly new..square pin) as the slave.
Any advice appreciated, as usual! Thanks Beej
Aurora 9 - Trainer / Buddy system Master & Slave function Set-up. & Data Transfer A9<>A9.
As well as posts 13 & 15 in regard to use of Futaba mini square plugs.
Note comment that Futaba are good for standard Acro without much mixing but do not use for Heli training as the cyclic and trims are different.
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)
#3504
My Feedback: (26)
TX
Looks like my batteries are toast! Tried a few 1700 MaH NiMh
s on my new A9 setup with GPS module, moving the sticks around I am getting low voltage warnings (6.0v 5-cell), on either pack. A9 set to 5.5v LBW. I am using one for the BAT port, and one to power the sensor station. These batteries are new but on the shelf for 1 yr. maybe 2 with ZERO usage. Should I go 2S LiPo for the SPC, and NiMh for the servos?
Also I did'nt get any instructions for the Sensor Port, does it need a seperate battery, or power off of a servo port on the Optima 7..??
#3505
ORIGINAL: Prop_Washer2 Looks like my batteries are toast! Tried a few 1700 MaH NiMh
s on my new A9 setup with GPS module, moving the sticks around I am getting low voltage warnings (6.0v 5-cell), on either pack. A9 set to 5.5v LBW. I am using one for the BAT port, and one to power the sensor station. These batteries are new but on the shelf for 1 yr. maybe 2 with ZERO usage. Should I go 2S LiPo for the SPC, and NiMh for the servos? Also I did'nt get any instructions for the Sensor Port, does it need a seperate battery, or power off of a servo port on the Optima 7..??
Aurora 9 - Battery is not charged. Charge before first use so as not to damage battery. Battery is 1300 mAh_charge rate is 80 mAh (to minimise damage if left on to long at any time) = 19-20 hours for first full charge - please read the further details.
Powered from the transceiver with separate lead, refer text &pictures:
Telemetry - Instruction Sheets & User Guide with pictures plus Enhancements Under Development.
Alan T.
#3506
My Feedback: (26)
TX
Great info Alan, you are the MASTER..!!
How about the optical tach sensor, is it for Heli's only or can I mount it on the top or bottom of the fuse behind the engine, perhaps aim it mid-way thru the prop arc..??
#3507
PA
Hello Hitec Team, I purchased the Hitec A9 system becuase of price and value & featuers, but the receivers and the new 6 LITE are still expensive?
The 6 LITE is priced mainly around $50 & $52 ????
We thougth the future micro Rx would be another $10 to $20 below the standard 6, but so far has Not happened?
When will hitec put these out cheaper than the Micro 05s ?
Many of us have to outfit a fleet from FM & Spectrum, but at $52 + shipping a pop is a chunk of change?
So far, my sons Optic 6 has both the FM & 2.4 modules, so for the moment we are using the micro 05S'..., but now buying the Corona FM receivers while we wait for your price drop?
Corona RS400 FM Full Range DSP Receiver $11
What is the business plan and timing for the $20 to $25 to $30 receivers?
Also, is there any online stores with a SALE on the 6 LITE ?
When will prices drop on all receivers?
Thank you!!!
Thank you!!!
#3508
ORIGINAL: GizmoMadMax Hello Hitec Team, I purchased the Hitec A9 system becuase of price and value & featuers, but the receivers and the new 6 LITE are still expensive? The 6 LITE is priced mainly around $50 & $52 ???? We thougth the future micro Rx would be another $10 to $20 below the standard 6, but so far has Not happened? When will hitec put these out cheaper than the Micro 05s ?
So far, my sons Optic 6 has both the FM & 2.4 modules, so for the moment we are using the micro 05S'..., but now buying the Corona FM receivers while we wait for your price drop? Corona RS400 FM Full Range DSP Receiver $11 What is the business plan and timing for the $20 to $25 to $30 receivers?
Also, is there any online stores with a SALE on the 6 LITE ? When will prices drop on all receivers?
Thank you!!!
Thank you!!!
Please remember clones do not have to pay for all the design research and degree of tooling revisions, simply back engineer and copy e.g.check out the many small RTF sets with TX identical cases to a top F brand then open and find little substance.
Cheap DIY "Lite"Hitec options have been available for a long time..
Optima Receivers - Light Weight Minima 6E, 6T Receivers & new Optima_6 LITE Transceiver
- also Caseless Weights for 6 & 7ch Optima Transceivers.
Optima Transceiver (RX) - Conversion for Indoor and Park-Flyers and Alternate Lightweight 2.4GHz Antenna.
Hitec "Factory Pilot" Brandon Chitty uses the Optima 7 in his indoor competition Fancy Foam Maxima that weighs 8oz, as well as his 170CC DA powered 42% Aeroworks Yak.
Doubt the new Minima 6, even without Telemetry, will ever be in the $20 price range and still meet market expectations for a genuine Hitec product.
FWIW just this morning had two local club membersjeering as to why the popular HS-55 servo was more expensive than a HK copy. Put two of each brand servo on the bench with identical set ups and showed the current draw of the cheap servo with cheap motor was almost double - reason for most of their brownouts albeit with another popular USA RC system.
Alan T.
#3509
NY
You can get the Optima 6 lite from Tom's RC online for $44.93 if you sign up for an account. Shipping is $3 usually.This is about the same price as the full size 6 channel and it looks like they both have the same specs except for weight and volume. They have good service and prices on most Hitec stuff and I have bought several Rxs from them. They are also on Ebay as tti.
If you want a good price on an Aurora 9/7 channel system see A Main Hobbies online. $325 with free shipping after discount code: DPPMAR1125. Good to the end of April and you can get a free 7 channel Rx from Hitec too!
http://shop.tomsrc.com/product_info....oducts_id=2786
I think it is wishful thinking to expect a quality RX with TM from Hitec for $20-$30. Maybe Hobby King will steal the technology and do it eventually.
Have fun
Have fun
#3510
Can anyone tell me how to make the startup conditions be model specific, as since the update to 1.08 they have all become system wide. Additionally how do you now cancel the low battery warning when it activates. I have to walk out to my combat wing with the TX beeping away !
Thanks.
Thanks.
#3511
PA
Thanks for the replies, and along with them, i still have some questions.
I was actually looking for the 4 gram class micro (or maybe called almost nano class) weight...
Will the new minima come in around 4 grams with the case removed?
Where can we purchase the minima 6E, tower does NOT have it available yet, ah bummer, i am striking out all over here for the 4gram class?
Model -................- With Case -..........- Case Removed
Optima 9 -...........- 23g -........................- ?
Optima 7 -...........- 17g -........................- 9- 10g ??
Optima 6 -...........- 15.3g -.....................- 7-8g ??
Optima 6 LITE -....- 10g -.......................- ???????
Optima 9 Minima -.- 6.5g -......................- ???????
* #1 I have a whole stack of the Hitec Micro 05S FM Rx's in my stock from replacing them this past year with Optima's, but they WEIGH 8grams... too heavy for my son's Raptor GS that really needs a 2 to 4 gram Rx...
* #2 Then my Nephew just picked up the TechOne micro indoor flyer that also needs a 4gram or smaller Rx.
>> Hint, the kids are now paying for 80% of their gear with their earnings and allowance money, so money is a big issue. everytime i turn around they are swapping or grabbing another plane at a RC flea market and dad is no longer buying their optima 6's at $50 a pop....
** Now my son has the optic 6 with both the 2.4 module & the FM module (while dad has the A9 )
***Q&A*** So do I keep the price down and go with one of the following?
1. Corona RS410 II for $11 + $2.50 for crystal $12.50 (Bphobbies)
2. Castle Creation Berg 4L 4g full range receiver, autoshift, FM, good features like failsafe, etc $30 (plus crystal $7) = $37 (Towerhobbies)
3. GWH pico but limited range and shift specific for JR vs hitech, etc compatibility $20 + $7 crystal $27
4. Nano 2.5gram ZX Technology R4J Nano Receiver for Aircraft $11.25 + $2.50 for crystal
http://www.bphobbies.com/view.asp?id...4&pid=C2680119
Doesn't look like we can shave the Micro 05S to 5 grams, unless someone here can educate us on some tricks? maybe the old dremel tool to shave off some black plastic around the connectors, but maybe only an ounce????
Micro 05S with crystal & no case - 9grams+ i suspect
So maybe use my son's optic 6 & FM module, while we wait for the Minima 6 and 4 gram'ers to come around? But then again, the kids can't afford it...
So old forums from 2007 show the old corona rs400 was junk, but now i see this newer corona rs410, so assume it is fixed and a good full featured great priced Rx??? any thoughts from all your experiences out there?
So I am digging here to figure out what to do???
Thanks so much in advance for the help everyone!!!!
#3512
PA
** Bind & Fly area also**
Of coarse my JR/spectrum buddies rail my A9 choice and BNF situations that keep jamming me and others up....
So that begs the next question:
When will hitec supply us with a nano BNF Rx to replace all those spectrum Rx's on the goodies out there?
#3513
My Feedback: (41)
Thank you!!!
Thank you!!!
#3514
PA
Well I could remove the case, but it is still 8 or 9 grams, where we need to be around 4 grams for indoor micro flyers like the RaptorGS and the TechOne
RaptorGS - 16.5" wingspan - AXON Raptor GS
http://flyairhobbyrc.com/axon-raptor-p-885.html
http://www.rcgroups.com/forums/showthread.php?t=1073163
TechOne Mini-Yak54 16.5" wingspan
http://www.techonehobby.com/proview.asp?id=184
#3515
ORIGINAL: rogerkeatley Can anyone tell me how to make the startup conditions be model specific, as since the update to 1.08 they have all become system wide. Additionally how do you now cancel the low battery warning when it activates. I have to walk out to my combat wing with the TX beeping away ! Thanks.
Aurora 9 - Firmware Update V1.08 Manual....
refer to: .Screen shots of the new displays plus additonal information and attached pictures..
2. Negative to a total turnoff of alarm, however there is an easy reset =
• Timer Reset Method: Press & hold the Timer (1 or 2) screen for about 2 seconds which you want to reset.
Aurora 9 - Timer x 3 Set and Beeps. Count Down/Up Set On/Off % of Throttle Stick Movement and reset method for V1.04<V1.07.
partial extract
"Aurora has a total of three timers.
. Two can be assigned to count either up or down and assigned to be activated via a switch or the throttle stick.
. The third timer is an overall timer to show how long the radio has been powered up. Reset this after charging the batteries so you can track the runtime of the radio and estimate how long until you will need to recharge
. Timer beeps every one minute and then once ever second at the 20 second to go mark and then twice every second for the last 10 seconds."
Aurora V1.07. - Timer: Improved Functions
Aurora 9 -Warning Alarms
"Battery Low Voltage Alarm - Voltage alarm may sound on Aurora when RX/Power battery is disconnected. This is because the telemetry cycles about 3 times/second, sometimes when you are unplugging the battery it will sense the voltage drop and the warning will kick in, but sometimes it won't because once you unplug the battery there is no signal going back to the TX. This is a hit and miss thing due to the way the system works."
This cannot be silenced except by turning the TX Off, a good reminder..
Alan T.
#3516
Due early next month, is the Minima 6T which is 6g but you can get it down to 4g with the plastic case removed. http://www.hitecrcd.com/products/new.../minima6t.html
Mike.
Mike.
#3517
Thanks A.T.
Earlier posts by Mike on the 1.08 update seem to infer that the startup settings (High Throttle, Abnormal Flight Condition etc.) are model specific as - “Warning at Start Up†setup can be applied to all models in the radio at once by selecting “To All Models†would imply, but I cant't find a 'To All Models' button I want these settings to be model specific as High Throttle for example is not relevant to a glider but is to an electric model.
Mike's earlier post also contains "4. Reset for battery alarm. " i.e. silence the low battery warning when it activates. Again I can't find how to do this ?
Or maybe I am missing something ?
#3518
I thing the select to all was a misunderstanding on our part as now these settings are global and apply to all models.
The battery alarm override did not make it in to this update as it was more difficult to integrate than expected but we hope to have this available in the near future with a minor update like V1.08(1).
Mike.
Mike.
#3519
Hi Mike,
Thanks for the info, I think I'll go back to 1.07(1) for the meantime as the startup settings are now only ever right for half my models, I fly petrol, glow, electric, scale gliders and HLG with the Aurora. I think pretty much all these settings should be model specific as most people fly a variety of different types and flexibility is one of the Aurora's strengths. This reduces flexibility. I still think the radio is fantastic value for money and just wish we could get hold of more of the add-ons in the UK where the radio is not well marketed, though the aftercare is good.
#3520
mike
tower now shows minima not due till late june for the 6t late july for the 6e. Is this correct or still april for the 6t?
thanks,
Bob S
thanks,
Bob S
#3521
Hi Mike,
Hi Mike,
Mike.
#3522
Hello Mike,
So I (we) just end up using the lowest common denominator and turning all the warnings off, or having warnings come up which don't apply to the model in use. Seems a bit pointless in having the feature then if can't be applied in a meaningful and useful way.
#3524
Can anyone tell me how to get the Butterfly mix to be 'always on' i.e. it doesn't need to be linked to a switch, this was supposed to have been changed in 1.08 but I don't think it has.
Thanks.
Thanks.
