New Hitec Aurora 9-Channel 2.4Ghz Radio System
#4326
NY
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Well the solution is simple. Buy an extra Rx or two and get them updated. Then cycle two at a time of your old ones through Hitec to get up to date.
Updates do not occur every month, I think there have been 3 or so in two years.
Hitec did not make these updates for no reason!
God forbid one of your most valuable airplanes goes wackey and is lost. At that point you will be rushing to get all the systems upgraded but will be one plane too late!
Think about it.
Jim D
Think about it.
Jim D
#4329
Recently I updated my trans & module to the latest versions. I also updated my 7 & 9 chan recvrs. all went well and no problems. NOW i went to fly a little foamie that has an older 6 ch rcvr, the servos function ok but i keep getting 3 quick beeps approx every few seconds. don't believe this is any of the alarms as i have tried making them all inactive. I also noticed that on this 6 ch model, the transmitter module has a solid blue light and a flickering red light. The rcvr light is solid red. I have tried rebinding with no change.
Maybe I'm just having ANOTHER Senior moment!
thanks,
Bob S
thanks,
Bob S
#4330
AB, CANADA
ORIGINAL: A.T.
Scenarios
1. Old Tx, old 6 ch Rx no updates - No problem except system not operating to full potential with slower reconnection, especially near ignition type interference recovery may not occur in time to avoid terra firma
or simply lock out.
(Use Normal Mode, not Scan Mode - scan mode has been changed to Scan Function)
2. Old Tx, new 6ch Rx - Will not connect.
3. Old Tx, new 7 or 9 ch Rx. A9 Firmware 1.03<1.06, Spectra V1.01 = No, will not link. (new Rx have V2.02 printed on end of box)
A9 Must be updated so as to cope with the Spectra module which must be updated to V3.01, then yes.
4. Old Tx updated, old 6ch Rx no updates - AOK, as in #5 below and the LED sequence on linking will not be exactly as shown on latest Spectra manual - refer
http://AFHSS - <b>ID_Setup <font siz... Procedure</b> for
........Aurora 9, Spectra 2.4Ghz Module Optima Transceiver or Minima Receiver.
5. New Tx updated, old 6ch Rx no updates - (Spectra Module must also be updated)
This is how I run mine in sports models without any issue to date.
However, as the transceiver update does ensure a much faster reconnection in the event of anything
similar to ignition interference or of a brownout, I would personally send any older Optima 6ch used with
petrol ignition or in expensive high performance models in for the update.
New Optima 6ch do have V2.02 printed on end of the box - suggest user puts a suitable sticker or mark on
case to identify the unit as such.
Alan T.
ORIGINAL: wkevinm AT Thanks for trying to make this clear, but I find the subject is still not black and white. I read that post and assume EP stands for electrics. I do not run electrics, rather most are high performance glow engines in composite fuselages. Not sure why the reference to EP and not glow for 6 channel. Can you indicate in the following scenarios if there are any compatibility issues with the TX and RX operating glow engines. Scenarios
5. New Tx updated, old 6ch Rx no updates Kevin M
or simply lock out.
Alan T.
AT, Thanks for the information.
This is the type of info I required to make a decision.
Kevin M
#4331
ORIGINAL: rs402931 Recently I updated my trans & module to the latest versions. I also updated my 7 & 9 chan recvrs. all went well and no problems. NOW i went to fly a little foamie that has an older 6 ch rcvr, the servos function ok but i keep getting 3 quick beeps approx every few seconds. don't believe this is any of the alarms as i have tried making them all inactive. I also noticed that on this 6 ch model, the transmitter module has a solid blue light and a flickering red light. The rcvr light is solid red. I have tried rebinding with no change. Maybe I'm just having ANOTHER Senior moment!
thanks, Bob S
thanks, Bob S
Aurora 9 - Startup Warning Alarms Disable / Enable Alarms and Model Match FAQ.
(The separate LBW in the spectramodule can also be set so it does not activate)
2. Three beeps every now and then is a clear warining that your transceiver voltage is dipping
below the minimum set in you Aurora ( or Spectra module:
AFHSS - Warning Beeps Aurora 9 & Spectra 2.4Ghz Module - Interpret & Manage the Independent Alarms.
extract:
"2. Check LBW set on both the TX and Module.
. Aurora Internal Alarm for Low Transceiver Battery power = beep, continous rapid.
(When a model has been programmed with say a 3S battery 9.9v LBW setting and a 2S even fully charged at 8.4v is to be used,
alarm would be tripped. Thus LBW setting for that model must also be changed).
. Spectra Module Low Transceiver Battery warning provides triple beep = beep beep beep pause beep beep beep pause.
(When using SPC from EP power battery and module has been programmed with say a 3S battery 9.9v LBW setting and a 2S even fully
charged at 8.4v is to be used, alarm would be tripped. Thus LBW setting for that model must also be changed via HPP-22)"
3. Pleasereset the link, ensuring only the red LEDis flashing on the Tx modulebefore turning on
the V1.01 Optima 6ch.see attached picture.
(Given that blue indicator on your Tx, your other Rx may also need have the ID-setting (link) reset.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
#4332
Thanks Alan,
I set the link and it works fine now. must have had senior moment rhe other times i tried to reset the link.
#4333
ORIGINAL: rs402931
Thanks Alan,
Thanks Alan,
Wow , ............... I thought I was the only one who got those . Glad I,m not alone
Michel
#4336
No nothing on the receiver itself. I bought mine in a three pack that has a version number on it. I would be extremely hardpressed to belive you have anything but the latest version due to the fact Tower sells a ton of these. I'm putting the version number on mine since there is no other way to tell. No data port so you cannot hook it up to your PC to verify the version number.
John
John
#4337
ORIGINAL: Guitarman52 I purchased a 6 channel from Tower a couple weeks ago but the box has no version on it.
Is there anything on the receiver itself?
as being V2.02 before Christmas 2011.
For information, if an old box found at back of shelf, as a minimum it should be V2.01,
Optima Firmware history is as follows:
HPP-22 Software & Telemetry Updates
Optima 7 & 9 Channel Receiver Updates
October 7th, 2011
Optima 2.4 GHz Receiver Firmware revision History
Optima Receiver Manual (updated)
Optima Receiver Firmware Version 2.02 – Released October 7, 2011
Improved reboot function
Improved noise rejection capabilities.
Optima Receiver Firmware Version 2.01 – Released July 31, 2011
Improved reboot and recovery methods after severe RF interference.
Optima Receiver Firmware Version 2.00 – Released July 15, 2010
Added HTS-SS Sensor Station compatibility
Improved Fail Safe Improved initial position of the servo when link is completed.
Optima Receiver Firmware Version 1.01 – Original Release
Alan T.
#4341
Hi
Well,................ lets see ,...................... If we go buy what AT , wrote down in the above post ,: "YES " they have to be sent in for updates . post OCT 2011 . I only have one 6 channel , so I,ll send it in , and get it over with . From this moment , they will be all 7 channels . I,d like Hitec to mention this fact , that " ALL " 6 channel 2.4 receivers , have to be sent in for updates . They don,t mention it anywhere in the advertizing . I think it,s just being honest . Advantage point for there sales , " NOT " to tell us .
Michel
Michel
#4342
ORIGINAL: michel gravelle Hi Well,................ lets see ,...................... If we go buy what AT , wrote down in the above post ,: "YES " they have to be sent in for updates . post OCT 2011 . I only have one 6 channel , so I,ll send it in , and get it over with . From this moment , they will be all 7 channels . I,d like Hitec to mention this fact , that " ALL " 6 channel 2.4 receivers , have to be sent in for updates . They don,t mention it anywhere in the advertizing . I think it,s just being honest . Advantage point for there sales , " NOT " to tell us .Michel
""YES " they have to be sent in for updates . post OCT 2011 "
- it does not mean every 6chOptima has to be sent back,
it simply stated that the user can not peform the upgrade themselves,
Please refer back to post
http://www.rcuniverse.com/forum/fb.asp?m=11014429where
I mentioned that very few 6ch Optimahere,have been upgraded
and as mentioned in another post, even my own 6ch ofV1.01 vintage
have not been updated.
As far as I am aware, the provision for upgrading receiver firmware
is another first by Hitec. No other knownmanufacturer has ever provided
firmware upgrades for receivers, user has always had to buy the latest model.
Alan T.
#4343
ORIGINAL: A.T.
Hold up, please re-read in context, the
''''YES '' they have to be sent in for updates . post OCT 2011 ''
- it does not mean every 6ch Optima has to be sent back,
http://www.rcuniverse.com/forum/fb.asp?m=11014429 where
I mentioned that very few 6ch Optima here, have been upgraded
and as mentioned in another post, even my own 6ch of V1.01 vintage
is another first by Hitec. No other known manufacturer has ever provided
Alan T.
ORIGINAL: michel gravelle Hi Well,................ lets see ,...................... If we go buy what AT , wrote down in the above post ,: ''YES '' they have to be sent in for updates . post OCT 2011 . I only have one 6 channel , so I,ll send it in , and get it over with . From this moment , they will be all 7 channels . I,d like Hitec to mention this fact , that '' ALL '' 6 channel 2.4 receivers , have to be sent in for updates . They don,t mention it anywhere in the advertizing . I think it,s just being honest . Advantage point for there sales , '' NOT '' to tell us .Michel
Alan T.
Spektrum has provided firmware updates for their receivers, but they have to be sent in to be upgraded.
#4344
Hi
I hold nothing against Hitec , ............... it just would of been nice to know beforehand , thats all . I apologize if it wrote( the post ) that I didn,t appreciate Hitec . I believe they have helped our hobby by bringing the prices down . At least thats the way I feel .
Sorry about that
Michel
Sorry about that
Michel
#4345
NY
Maybe we should retitle this topic "6 Channel RX whining"!
We were all so glad to get a full perfomance Rx with battery TM that we did not notice it did not have a data port but we did like the $40 price right?
Time to move on and go flying!
Jim D
Jim D
#4348
Hi
Sorry about that
Michel
Hi
Sorry about that
Michel
#4349
I am presently setting up an all carbon hotliner and intend to use a minima receiver because of the dual antenna. About the only way I can see to exit the antenna through the fuse is just under the wing saddle. This will mean both will face the tail one on each side the fuse. Though not at an ideal 90 degrees to each other I was wondering if there might be any problems. I need to retain this configuration for best aerodynamics. I will have to either tape the antenna to the side of the fuse or protect it by sliding it inside a small piece of antenna tube. Any other ideas or suggestions?
Dennis
Dennis
#4350
ORIGINAL: Propworn I am presently setting up an all carbon hotliner and intend to use a minima receiver because of the dual antenna. About the only way I can see to exit the antenna through the fuse is just under the wing saddle. This will mean both will face the tail one on each side the fuse. Though not at an ideal 90 degrees to each other I was wondering if there might be any problems. I need to retain this configuration for best aerodynamics. I will have to either tape the antenna to the side of the fuse or protect it by sliding it inside a small piece of antenna tube. Any other ideas or suggestions? Dennis
{Regularily Updated with Q&A}
especially the section on "Sailplanes & Carbon Fibre Fuselages
and . Dual Antenna Mounting pictorial.
By Joe Manor of his set up for high speed DSS, see video below. "
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
