Dual elevator lag with Futaba 10C noticeable?
My Feedback: (90)
It seems that servo grouping is not possible with 10C. At least the manual does not describe it.
Without the grouping feature, will a dual elevator servo setup with 10C tx and receiver exhibit synchronization problem? Has anybody tried and if so what is your observation?
I have a 9C and am always concerned with synchronization in the dual elevator servo setup (with 9C).
I am thinking switching to 2.4Ghz and would like to see the problem gone after the upgrade.
Thanks for any feedback.
My Feedback: (41)
RE: Dual elevator lag with Futaba 10C noticeable?
ORIGINAL: john911
the only time i had synchronization problem is when my push rods were not =
The 9C was notorious for that elevator lag issue and as to the OP's question, I saw Bax say over on the Futaba manufacturer's support forum pretty much exactly what exeter_acres said.
My Feedback: (41)
ORIGINAL: nonstoprc
Maybe we should ask how close the two elevator servos can be under 10C?
Anybody tried 10C with a dual elevator setup?
