Range loss?
OH
Range loss?
Will I lose range by doubling back my antenna as shown in the picture, as opposed to letting it hang out the back. I've been flying one plane this way but I've been keeping it within 400' and it seems to work OK. I would hate to loose a plane because of doubling the antenna back this way, but when it hang out the back of the plane it is easy to step on the antenna.
Thanks for the help.
RE: Range loss?
ORIGINAL: propjobbill Well; that's what I needed to know, I don't want to find out the hard way. Thanks
"Antenna - Rubber Duckie, Micro & Whip Flywire - replace long aerials with loaded base antenna"
"Range check and Range problem solving"
"Receiver - FAQ, guides and aids to best reception."
at
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
PA
RE: Range loss?
Go for an Azarr M-72 antenna. EcubedRC's website seems to be down so here is another source: http://www.rctoys.com/rc-toys-and-pa...=EC-ANT-M-72-L
RE: Range loss?
Just let it trail behind the plane. I have several planes that the antenna trailed out the wing tip or tail. The only problem is you don't want to stand on the antenna wire as you pick up the plane.
OH
RE: Range loss?
I've already decided go strait with the antenna and don't modify anything. This article say everything I need to know http://rc-cam.com/ant_exp.htm It seams like the best thing you can do is use it the way it was designed and keep it strait.
My Feedback: (19)
NY
RE: Range loss?
If all this was true all pylon racers would fall from the sky. They routinely wrap their antennas internally. I've done it many times.
I would double that antenna without even thinking about it and never notice a bit of problem. Keep in mind that that is a very small model and therefore you will keep it closer just to be able to see it. Any theoretical loss of range will be compensated for by that alone.
HiTec even supplies a bobbin with their receivers to wrap the antenna. I'll have to go down and look at the instructions but I seem to remember they recommend no more than half the length should be wrapped. The antenna wire should never cross itself, however.
NC
RE: Range loss?
Fiddling with the antenna will shorten the range of the receiver, but the main question is will it shorten the range to the point where you loose control of the model.
Consider:
Let's assume for a moment, that the range of a full range receiver with a 40" antenna is 2,640 feet (1/2 mile). Then based on the data referencing antenna length to db loss found in the link supplied by propjobbill, going from a 40" antenna to a 19" antenna reduces the signal by -7.7db, or just over the -6db referenced which will drop the range by a little over one half (see (2) under Decibels for Dumbbells in that link). For a park flier, would you really be in danger of loosing the aircraft going from 2,640 feet to somewhere around 1,000 feet?
Also, nowhere in that article could I find a reference to an antenna that's folded back on itself. But even if that is a consideration, and the signal is reduced by the -7.7db referenced in the article, we're still looking at a range of around 1,000 feet.
Just remember, for us here in the US, a football field is 100 yards, or 300 feet. That would put the effective range of a shortened or doubled-backed antenna somewhere between 3 and 4 football fields.
I don't know about you, but I doubt I could see my small park flier airplane 3 football fields away.
Bill
Consider:
Bill
OH
RE: Range loss?
I can tell you that at some place between 400' to 500' these small planes get so small in the air that it is hard to tell what you are doing. I try to always remain within 400' of less on planes 36" or smaller. So I do think that it is true that range is not a problem for these small planes unless you are using a small receiver rated at 500' to 650' then it would be a possible problem. I do have a couple of receivers from BlueBird and GWS that have these short range ratings. But these are probably designed for indoor flying and weight 4 grams or less. I have never found it a problem on my larger .40 or bigger planes with the antenna being to long.
Thanks for the comments and information.
RE: Range loss?
ORIGINAL: Stripes
>snip< HiTec even supplies a bobbin with their receivers to wrap the antenna. I'll have to go down and look at the instructions but I seem to remember they recommend no more than half the length should be wrapped.
Regards
Alan T.
MD
RE: Range loss?
I used to rap mine all the time without any issues and still do on a few of my planes.
But I now regularly use the micro antenna...I love them.
Skarn
Skarn
OH
RE: Range loss?
Yes the wing was on backwards in that picture. I didn't even notice until after taking the picture, but that was OK I only I only put it on to take the picture. It is not yet ready to fly, it still needs an engine on it.
My Feedback: (13)
NC
RE: Range loss?
I routed one out of a eflite mus and taped ot to the bottom of the horizontal stab. It looks neat and you have to step on the airplane to step on it. My other airplane has a optional pullpull rudder and I routed the wire out it with about 3 inches hanging out.
Alan
Alan
