Flash 5SX
Flash 5SX
Hi!
My question may not make any sense to most people but to the ones it does, please, HELP!
What is "CAR F1" about?
Many thanks.
Greatings from portugal!
Many thanks.
RE: Flash 5SX
ORIGINAL: pedace Hi! My question may not make any sense to most people but to the ones it does, please, HELP!
What is "CAR F1" about? Many thanks. Greatings from portugal!
Flash "Pro-Car" TX has menus for both Car and aircraft and uses similar menus and operation for ATV and EPA. Convert to and from aircraft version by removing/replacing the directional blocking plate from each stick and change menu. Gave away manual, with TX, some time ago when Eclipse Pro-Car emerged. NB: there are major differences in procedure for saving input and trim adjustments between first and SX versions.
If using a 5SX, then CAR F1 shouild not be an issue as noted under
"Hitec Flash 4 & 5 - DIY Double Memory"
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
