Futaba 10C and reflex
Anyone set up reflex xtr flight sim to work with the 10C? I cant seem to get mine working dont want to have to buy another sim
ON, CANADA
RE: Futaba 10C and reflex
What is it not doing? Are you getting any signal from radio to the software? Any channel movement at all?
Are you using a "dongle" version or a *cough* "optimized" version?
Perhaps the pinouts are wrong if you are using the reflex adapter?
I use one of the $10 GWS USB adapters for 10c -> USB and it works great.
Cheers,
Andrew.
Cheers,
Andrew.
Got it working now, here is the juice.... all you have to do is when you plug in your square plug make sure you choose Fm ppm not 2.4.... works a treat now and also I converted my old JR lead to the Futaba... what aftermarket dongles can you get never heard of that?
