Futaba Gimbals, 10C, 12FG, 12Z ?
TX
Guys, I requested some information on the Futaba Support Forum and it was not answered. I posted the question in January and sent reminders. I still don't have a response, three months later. So, I am going straight to the best source, the consumer. What I would like to know is:
1. Which of these three radios have ball bearing gimbals?
2. Does each gimbal have a ball bearing for each axis?
3. Do any of these have dual ball bearings per axis?
If you own one of these radios and know the answer, please post your knowledge.
RE: Futaba Gimbals, 10C, 12FG, 12Z ?
See the link below for a description for each from the NA Service Center.
http://www.rcuniverse.com/forum/m_8394150/tm.htm
Woodie
Woodie
TX
ORIGINAL: woodie
Woodie
Woodie
Neobob, thanks for the input. Have you had access to a 10C to check?
That same link explaining the gimbals and ball bearings says the following about the 10C:
"The 10C gimbal is essentially the same as the one used in the 9C, and does not have ball bearings. " (by Bax)
Woodie
Woodie
