AR6200 wiring polarity
Reply
Old 05-09-2009, 09:45 AM
Kaz the Minotaur
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AR6200 wiring polarity
What is the order of the sero wires for the AR6200? Negative to the inside of the RX?
Kaz the Minotaur is offline
Old 05-09-2009, 11:18 AM
codimasta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AR6200 wiring polarity
Neg is always facing the bottom...power plug faces tp the left ...with the plugs facing you
. signal
. pos
. neg
I am not sure that the 6200 has a power plug on the bottom
Hope this helps
codimasta is offline
Old 05-09-2009, 01:53 PM
Dorsal
Dorsal's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just plug them in. If they work, great - if they don't then turn them around. The connections are arranged so that you cannot damage anything by connecting them backwards, you can only ground out the signal wire, which, of course, won't work.
Dorsal is offline
Old 05-09-2009, 02:12 PM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a couple of AR9000 Rx's and several AR6100's. The connector polarity is marked on the end of the Rx case, in line with the connector pins. I would think the AR6200 would have them as well.
The Black wire is on the side towards the End of the case, in the AR6100. This is the AR6100 that has the connector pins pointing Up from the Top of the case. There is another AR6100 with the connector pins coming out the End of the case.
BuschBarber is offline
Reply
Display Modes
