(2) 149DP receivers not working
My Feedback: (212)
NC
I have 2 receivers bought on ebay,they are net working with my futaba 9cap tx.Where is a tech shop that can check / test or repair these receivers? Thanks
RE: (2) 149DP receivers not working
Did you set your TX to PCMmode??? If you have a synthisizer RF module check to make sure you have it set to the right channel.I sent mine back because it wasn't working only to find I had set it 10 channesl off the one I was shooting for.
Don
Don
My Feedback: (212)
NC
Yes,it is in PCM mode,it is not a synthesized module,proper crystal is in rx and I have powered off and on to make sure the PCMmode was activated. Thanks
