is it safe to run 4x 200oz non digital servos from 2 aileron channels on my spectrum dx7
this is 2 servos per aileron (2 Y leads)via aileron and aux 1outputs on standard dx 7(4 servos from 2 outputs) with no match box or powerbox on A 1/3scale cub.
servos are chinnese non branded anologue 15.5 kg output.
thaks for your help.
John New Zealand
CO
RE: is it safe to run 4x 200oz non digital servos from 2 aileron channels on my spectrum dx7
If your servos aren't fighting each other and you have a good battery set up you should be fine. Just make sure your servos aren't binding.
