Servo grease? Will clear silicon work?
Reply
Old 03-27-2002, 09:35 PM
OnTheEdge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servo grease? Will clear silicon work?
Will clear silicon grease work to lub the gear train in servos?
OnTheEdge is offline
Old 03-28-2002, 02:11 AM
Vince
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would not use silicone, as it congeals over time. I would use a light grease such as lithium, or lubriplate. Even vaseline would be better than silicone IMO. I am thinking of the silicone grease like to lubricate valves. Really you need very little lubrication in the gear case. Some new servos that I have had an occasion to open up didn't have any lubrication in the gear case. If I were to use any (which I wouldn't), I would use it very sparingly.
Vince
Vince is offline
Old 03-28-2002, 07:30 PM
SitNFly
My Feedback: (54)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where can you buy the silicone grease? I'm familiar with silicone sealant, but not the grease.
Rein
SitNFly is offline
Old 03-29-2002, 12:59 AM
flatfour
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can get a big tube at NAPA Auto. Sold as Sil-Glyde
flatfour is offline
Old 03-29-2002, 02:20 AM
Gene Chernosky
My Feedback: (182)
Gene Chernosky's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Silicone or White Lithium Grease??
Hey...you choose...both are good!
Silicone and white lithium grease should be available at any good hardware shop.
Just be careful not to pack the gears with too much grease...a little goes a long way...any more, and it slows down/binds the servo.
Gene Chernosky is offline
Old 03-29-2002, 10:32 PM
ftomteen4cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When I was doing pro audio repair, we had some kind of opaque black grease for lubing ADAT and DAT transport tape guide rails. It might have been metalized. It had the consistency of vaseline, and was only used for metal-on-metal.. I've seen the same stuff in VCRs. For nylon gear trains I was using lithium grease.
All I was told was that we bought it from Japan and it cost $$$ compared to other greases. Apparently, it was some high-quality stuff. Has anyone heard of it, know what it's called or where to get it?
ftomteen4cat is offline
Old 03-30-2002, 03:32 AM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Silicone grease
Ladyflyer: I was given a small container of grease made by Dow and I think it was of a silicone type. The person who gave it to me worked at a food processing plant. If I recall it said something about being a dielectric grease. Anyway I used it to lube gears in a fishing reel, but then used it to lube the pot in some of my older servos and it took the jitters out. All that was needed was a tiny dab on end of a toothpick. Then spread that out with clean finger. I am not home right now so I cannot read what it says on container. It was a neat kind of grease for sure. They may have far better stuff out now- right. Captin John
captinjohn is offline
