JR RX AILERON SET UP ?
Old 08-24-2009, 02:21 AM
freeair
Default JR RX AILERON SET UP ?
Guys , i have a JR 700 receiver combined with a JR 9X tranny, what i need to know is what receiver plug ends do i use for setting up the Ailerons without using a Y -Lead as i have allways used in the past ? i sort of know that one lead will go into the aileron channel and the other into Aux 1 or 2 maybe , then how do i set the TX ? thanks.
Old 08-24-2009, 06:38 AM
alan0899
Default RE: JR RX AILERON SET UP ?
G'day Mate,
You would use the AUX1 (flap) channel in the RX, check you manual page 14, & look for the mate function, in your TX, follow the directions, it's easy.
I have a DSX9, 2.4GHz TX, it uses the same programming as the PCM9X, V2.
You can also "mate" elevator servos, if you need to, & you don't need to use the flaperon function.
PM me if you need any further assistance.
Everyone on RCU is always happy to help.
Good flying.
Old 08-24-2009, 11:48 AM
AWorrest
The DSX9 transmitter should have a monitor menu like the US 9303. Use it to determine what each channel function is. The upper left channel is channel 1. Under it is channel 2, etc., the upper right is channel 5 and downward to the lower right is channel 9. The functions will move around depending on how you program the devicesel and wing type menus.
(another) Allan (from the US)
Old 08-25-2009, 12:57 AM
freeair
thanks very much Alan 1 and Alan 2. great assistance.
