Futaba FF9 or JR 3810 ADT???
IL
first, please let me state that if JR has changed anything else in the 3810 (8103 in the US) other than adding the digital trim, then the info provided may be inaccurate.
for a side by side comparison of these 2 radios AS THEY ARE SOLD IN THE US, please email:
[email protected]
with 9Cvs8103 in the subject and body of the email.
This will give you the pros and cons of each and specifically details all of the benefits the 9C has over the 8103 and the few benefits the 8103 has over the 9C.
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Service and Support
Great Planes Model Distributors
[email protected]
www.greatplanes.com
www.bestrc.com
[email protected]
Sincerely,
Mrs. AnnMarie Cross
[email protected]
www.greatplanes.com
www.bestrc.com
There seems to be a problem with the automated response... All I get is a general answer saying, among other things, I should post a message with 9Cvs8103 in the subject and message! And thats all I allready did!
/Nokke
/Nokke
IL
Sorry, Nokke! It shouldn't have triggered that way. I believe I have it fixed now.
Anyway, now that I'm at work I can provide you the info here:
8U and 9C vs JR's 8103:
The primary advantage the 8103 has is 2 extra models.Otherwise the 8U has more flexibility and functionality, and the 9C has even more, and easier programming.
Support for Futaba: We offer FAQs which are regularly updated, support the 9C owner's email mailing list, offer email support (typically answered in under 24 hours) and intelligent automated information.
Feature-by-feature comparison:
Ties:
the 8U/9C has campac ability vs the 8103s data safe and data transfer options;
The 9C and 8103 have 8 char model name; 8U = 6.
The 8103 and 9C have servo display.
8U +s vs 8103:
1 more switch
4 digital trims & idle down/thr. cut (more versatile than analog trim)
all 4 modes
normal & functional trainer
support for flaperon/ail diff w/5-ch RX
throttle channel expo
1 more linear mix in acro/glider mode but 1 less free mix, yet 1 more heli revo mix
snap programming has safety mode and direction switches
aileron differential programming within flaperon
vtail programming in acro mode
start offset and speed offset (progr. trim1 and trim2)
elevon in glider prog
an invert pitch curve
delay on its heli offset mixing
1 more swash type — HN3
governor programming
eprom memory and can't fail a lithium battery
a diode for reverse polarity protection
increased assignability (most mixes, etc, can be assigned to any switch in any position) for control of mixes and other functions, particularly dual rates
9C ADDS:
- HELI MIXES: the 8U has 2 free mixes, not multipoint, in the heli mode and 3 multipoint revo mixes; the 8103 has 3 free mixes, 2 of which are multipopint, and 2 revo mixes, not multipoint. The 9C offers 2 not-multipoint mixes and 1 multipoint mix, plus the 3 multipoint revo mixes, but no invert programming.
- HELI CONDITIONS: offers an option for sep governor, gyro, and dual rate settings per condition.
- Heli — 3rd idle up instead of an invert condition.
- Heli - throttle needle programming has 3 separate curves.
- Channel control selet for channels 5-9. The 8U does not offer this. The 8103 has channel control select for aux 2 (but far less switch assignability in other features than either 8U or 9C).
- 2 Sliders in addition to the 3 dials.
- A ninth, switch only, channel (available only with the 9Ch PCM receivers.)
- Easier menu layout for ease of programming.
- Programming dial for speed and ease of programming.
- TRIPLE RATES easily set up and assigned.
- Nearly 100% switch/channel/control assignability.
- Dial/Slider master control mixing capability — UNIQUE ONLY TO THE 9C.
- 4 separate programmable snaps.
8103 +s:
2 more model memory
the 8103 has acceleration mixing in heli mode
the 8103 can discharge the tx battery through the charge jack
Further comparisons: www.flash.net/~dynamic3 ; 9C vs the 8U: www.futabarc.com/faq/faq-9c.html
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Services and Support
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
Ties:
8U +s vs 8103:
1 more switch
all 4 modes
9C ADDS:
8103 +s:
2 more model memory
Sincerely,
Mrs. AnnMarie Cross
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
Thank you very much! Now I know better.
But there's still the same problem with the autoreply.....
Best regards
Reijo
Best regards
Reijo
IL
Thanks Nokke,
I think I found the problem this time! Please feel free to re-try it. thanks again!!
Sincerely,
Mrs. AnnMarie Cross
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
Sincerely,
Mrs. AnnMarie Cross
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
