Servo Install
Servo Install
I recently installed a new servo in my SC10. It fit fine and I thought all was well until I realized it turns further right than left. Is there a particular way to get it centered?
AB, CANADA
RE: Servo Install
There are a few ways.
1. You should always do it mechanically as much as possible, that means that you have power to the servo before putting the arm on.
2. Always use subtrim instead of trim when possible as sub trim does not move the entire arc of travel, just where the center is.
3. Use the end point function on the radio (if you have it available)
4. Use a servo programmer
Some of the above can only be accomplished on a computer radio.
RE: Servo Install
ORIGINAL: Congzilla I recently installed a new servo in my SC10. It fit fine and I thought all was well until I realized it turns further right than left. Is there a particular way to get it centered?
Servo Installations. Numerous examples/methods to fit servos into fuselages and wings.
Differential - Mechanical set-up - Correct Dutch roll and Drag. may also assist.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
