Exceed RC 6-Ch 2.4Ghz Radio?
CA
I saw this:[link]http://www.nitroplanes.com/2-4ghz-transmitter-receiverfull-versionfor-rc-helicopters-airplanes.html[/link] on the nitroplanes site and I'm wondering if anyone knew if it was any good. Sixty buck for a 2.4 Gig system seems a bit sketchy, but maybe technology is moving as fast as they say. Thanks
-Chris
-Chris
RE: Exceed RC 6-Ch 2.4Ghz Radio?
There was a mention of this system in the AMA(?) magazine in the last month or so. I don't have the magazine anymore to reference, but it seemed as though it worked ok and as long as you had a laptop at the field to program it with. I would maybe try one on a foamie to see how it worked.
This radio is the same (excluding brand) of the Turborix you can read of here:
http://www.rcuniverse.com/forum/m_81..._1/key_/tm.htm
I have two of them and it works good, you can find even better prices on Ebay!
purchased one from Hobbypartz.com last year.......used it all summer in some pretty electronically places and had no trouble........took a little to get the mixing functions I wanted programmed correctly..........The programming does work when you follow directions.........I just purchased another and it is programmed, up and running.
