Does anyone know the specs on a Futaba Receiver R136 F
My Feedback: (185)
WA
Hello
I have a R136 F 72mhz Receiver, and would like to know the specs on it? I can't find any information on it any where.
1. Range
2. Type of crystal (single or dual)
3. Voltage ( can it be ran a 7.2 volts
1. Range
RE: Does anyone know the specs on a Futaba Receiver R136 F
I can't find your receive on the Futaba site, and it goes back to the early 80s. The nomenclatur on the radio would translate to a 6 channel, FM, single conversion receiver. I would not suggest that you use more than 6 volts for a battery pack, even if the RX was OK, the servos would not like it.
Check the Futaba site. http://www.futabarc.com/radioaccys/old-receivers.html for more info.
Don
Don
ORIGINAL: rstearman I have a R136 F 72mhz Receiver, and would like to know the specs on it? I can't find any information on it any where. 1. Range 2. Type of crystal (single or dual) 3. Voltage ( can it be ran a 7.2 volts Thanks
"Designed from scratch, Futaba's standard 6ch receiver features a new PCB, improved performance and end servo connector insertion for easier access and installation. It's lighter as well!
Channels: 6Ch Current Drain: 11mA Dimensions: 50.3 x 33.4 x 18.1mm Weight: 27.8g"
A budget aircraft receiver, sold as full range, operating voltage 4.8 - 6.0v.
Seenin 35, 36 & 40 Mhz only to date. FWIW not all products Futaba produce are sold in USAand the Futaba USA site lists only those that are actually distributed by their agentHobbico (Great Planes Model) in USA..
Sold singularily, as above, or packaged with 6EXAP as shown
Futaba 6EXAP-fm 6CH PCM/Fm Radio System For RC Plane (TX + RX)
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
My Feedback: (185)
WA
Thank you very much for the info A.T., that was just what I was looking for.
I checked out Alan's Hobby, Model & RC FAQ Web Links,, Lots of great info.
Thanks again
Rick
Thanks again
Rick
