7C / DX7
TX
7C / DX7
Hi,
I wanted to get some opinions on the newer 2.4 ghz radios out there for my next purchase. I am looking at the Futaba 7C and the Spektrum DX7. They are both in my price range and have the features that I am looking for. I have been in this hobby for 20+ years and have always used Futaba until I recently bought an electric heli and tried the DX7. I liked it and it worked flawlessly, but don’t see it used a lot in fixed wing aircraft locally.
I was hoping some of you that have used both could give me an opinion on these and help steer me in the right direction.
Thanks…
Thanks…
MN
RE: 7C / DX7
The biggest cost in switching to 2.4ghz is that of the receivers. Look at what you'll need, what the price points are, and what the options are. There can be some big differences in total cost.
RE: 7C / DX7
If you do not have much of an investment in older 72Mhz Rx's, and you don't have any 2.4Ghz stuff, now, then you can go with any 2.4 system you like.
Try and get your hands on someon else's radio or one at a Hobby Shop or Trade Show and see how it feels. Look at the programming and figure out how many channels you might possibly need.
Look at the availability of Rx's in the size you noumally use. If you fly many small Park Flyers, some manufacturers have more of a variety than others in Micro and Mini.
If you already have a Tx that takes removable RF Modules, you could always buy a 2.4 Module for it and be able to fly 72Mhz and 2.4.
If you just want a new 7ch 2.4 Tx and do not need compatibility with the older 72Mnz stuff, then a DX7, 7C, etc., will do fine. There are other manufacturers that have 2.4 products, such as Hitec, Airtronics, and others.
TX
RE: 7C / DX7
ORIGINAL: codimasta
[8D]Since you already have a DX7..just buy a receiver for your fixed wing aircraft and enjoy
Codimasta
AMA 11269
Codimasta
AMA 11269
Thanks...
RE: 7C / DX7
I have used several AR6100 in electric aircraft and never a problem. On aircraft is the Eflite Beaver which requires a Full Range Rx. I have used the AR7000 and AR9000 in Glow, Gas, and Turbine Jets. They are fine. I have friends who have used the Futaba equivalents, as well.
