9z Transmitter Batterys
Reply
Old 04-01-2002, 02:01 PM
vinnyjet
My Feedback: (39)
vinnyjet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 9z Transmitter Batterys
I HAVE 2 600MH TRANSMITTER PACKS
CAN I REPLACE THE BATTERYS IN THEM.
LIKE TO GO TO 1600MH.
THANKS VINNY
vinnyjet is offline
Old 04-01-2002, 02:42 PM
amcross
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The easiest thing to do is purchase the newer 1100mAH transmitter pack which ships with the 9Z WC2.
FUTM1470 NT8S TX NICD 9.6V 1100MAH 9Z
amcross is offline
Old 04-01-2002, 02:53 PM
edge_fanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get the battery for the 9z at radicalrc dot com and you'll save a bit of money. Beware though that radical may not know how to bypass the diode correctly. He did mine incorrectly, and I had to redo it the right way.
edge_fanatic is offline
Old 04-01-2002, 03:10 PM
amcross
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please don't jump the 9Z battery within the case. The unit is in place in the case for several reasons.
Instead you can simply jump the diode when charging with a simple discharge jumper. You can make your own or buy one:
HSP78050 9Z DISCHARGE CONNECTOR 1 5.00 retail
You can ask your favorite hobby shop to special order these parts for you, which may provide you some savings from full retail pricing. Alternatively, you can purchase replacement parts directly from us, by simply providing us your mailing address and the stock # of the item you require, as well as a method of payment. You can fax or mail us with a credit card # or mail a check, or we can send COD for an additional $5.00 fee on top of the standard $3.00 shipping within US or $13.00 shipping outside US.
fax: 217-398-7721
Hobby Services Parts Support
1610 Interstate Drive
Champaign IL 61822
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Services and Support
Great Planes Model Distributors
productsupport@greatplanes.com
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
amcross is offline
Old 04-02-2002, 04:10 AM
edge_fanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
May I ask, what are the reasons that the unit is in place? And, under what conditions may the jumper be used? From what you say, it seems to be implied that you would use the jumper sometimes (while charging?) but not others (while the radio is on?).
Does this mean that you must charge the battery outside of the radio?
I know I'm jumping to conclusions...hehe....Just trying to think it out.
Old 04-02-2002, 05:56 AM
can773
can773's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need to bypass the diode to discharge (cycle) the pack, otherwise leave it in line as I beleive (and I have been known to be wrong on occasion ) it is there to protect the electronics from any sort of power surges or overloading, so without the diode then you could potentially damage some expensive components.
can773 is offline
Old 04-02-2002, 01:05 PM
amcross
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The jumper is used outside the radio solely for discharging.
The diode is in place to protect against power surges, lightning strikes, accidental reverse polarity (plug your leads in wrong on your charger or use your JR charger by accident), etc.
Sincerely,
Mrs. AnnMarie Cross
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
amcross is offline
Old 04-02-2002, 02:32 PM
edge_fanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!
Old 04-02-2002, 05:54 PM
Ergo60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had my local Batteries Plus make me some new 1100 MAH packs, and they only ran me 15.00 each!! I used them all last year with no problems. All I had to do was remove the screws on the plastic case, and solder the two wires on. Really easy, and man do they last longer than my old 600mah packs.
Ergo60 is offline
