FUtaba 9CA Raido Reading?
NE,
Ok ...Now I have a general idea how it works. So now what do I set it at to help me fly with more ease. Not to fly for me but to help me look better.
What settings should I be striving at? Most IMPORTANT... Are there any books to read explaining what control surfaces should be set at or be mixed with?
OK guys, whos out there that knows what going on?
Larrt
Omaha Nebraska
Larrt
Omaha Nebraska
Practice will make the plane fly easier. Setup of the radio and plane is up to you. You can set it really sensitive or not. Your choice. It won't fly it for you. The only way you can get that kind of help is with a co pilot, and I don't suggest that. Makes for a lazy pilot. Learn to fly the plane.
My Feedback: (16)
Until you gets lots of experience, don't worry about the mixes with the radio. You should train your thumbs first and then you can start to play with mixing. If you start messing with mixing, you could find yourself with a plane that is unflyable.
FYI- Jason Shulman's 3D video shows him with only one mix. Elevator to Rudder.
