Futaba 9CAP
Reply
Old 01-07-2010, 10:08 PM
tonyg11780
tonyg11780's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba 9CAP
Ok radio experts...and everyone else...
I need to upgrade from my current spektrum 5 channel 2.4ghz system to something with more channels. I would love to stick with 2.4ghz, but I have an offer on the table for a like new Futaba 9 CAP pcm with two receivers for 150.00.
I would like to know what everyones opinion is on this system. I have little experience with pcm radios. Actually none at all. I know about the radio impound that I am not having to deal with now and I am fine with that. I fly at small clubs anyway.
I know the initial response would be to stick with 2.4ghz...but for this price I think I could use the PCM for a while, and eventually upgrade the Tx with a module set.
What do you think for a buck fifty?
Thanks in advance,
TonyG
tonyg11780 is offline
Old 01-07-2010, 10:30 PM
ira d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba 9CAP
The 9CAP is a nice radio I have one and it can be converted to 2.4 with a module and receiver either 7 or 8 ch, I think the 8ch set will cost you about
300.00 which means you will be into the radio for about 450.00 total. IMO I think would go with the Airtronics RD8000 for about 250.00 and its a 8ch.
ira d is offline
Old 01-07-2010, 10:58 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tonyg11780 Ok radio experts...and everyone else... I need to upgrade from my current spektrum 5 channel 2.4ghz system to something with more channels. I would love to stick with 2.4ghz, but I have an offer on the table for a like new Futaba 9 CAP pcm with two receivers for 150.00. I would like to know what everyones opinion is on this system. I have little experience with pcm radios. Actually none at all. I know about the radio impound that I am not having to deal with now and I am fine with that. I fly at small clubs anyway. I know the initial response would be to stick with 2.4ghz...but for this price I think I could use the PCM for a while, and eventually upgrade the Tx with a module set. What do you think for a buck fifty?
Thanks in advance, TonyG
A good proven system which can be used with both exisiting module and upgraded with a 2.4GHz module thus you can swap modules and continue to use existing receivers.
Refer to recent thread this forumFutaba 9c conversion with hitec 2.4 system - Report
and especiallyCoupons and Pricing Comparisons
Spectra 2.4/Optima 7 Combo
Hitec RCD Product Details 2009
Hitec RCD Optima 6, 7 & 9ch Receiver Manual
Hitec RCD Spectra 2.4GHz Module Manual
Spectra Pro Antenna Mast Fitting to other than Aurora TX may also be of interest.
Aurora A9 - FAQ & Undocumented Features - Mixes, Setups, Tips, (includes Spectra Pro and Optima RX features) . {frequently updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Post Script:
Spectra Pro 2.4Ghz is also compatible with other Module Type Transmitters that use the same Futaba/Hitec module shape/size/pin slots. e.g.:
5UAF, 5UAP
7UAF,7UAFS, 7UAP,7UAPS, 7UHF,7UHFS, 7UHP,7UHPS
8UAF, 8UAFS, 8UAP, 8UAPS, 8UHF,8UHFS,8UHP, 8UHPS
(8FGA, 8FGH as non-module radios can not be accomodated).
9CA, 9CH, 9CAPS, 9CAFS, 9CHPS, 9CHFS
10CH, 10CA (10CAG or 10CHG as non-module radios can not be accomodated).
A.T. is offline
Old 01-07-2010, 11:16 PM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is limited to 8ch if you convert to 2.4 and you can only use Futaba PCM Rx's if you want 9ch on 72Mhz. You can use other manufacturer's 8ch PPM Rx's, like Hitec. The 9th channel is only a Switch. It is not Proportional. It is still a good radio with some limitations compared to the JR XP9303.
For the price, I would look at the Hitec Aurora 9. It can be had for just over $400 with a 9ch 2.4 Rx and a coupon for two 7ch 2.4 Rx's. You can use 72Mhz RF Modules and is compatible with Futaba PPM.
The Airtronics 2.4 radios are a good Bang for the Buck.
Of course, the Futaba 7, 8, 10,12, and 14ch 2.4 radios are nice systems but more expensive.
The JR X9303 and 12X are nice radios, as well. JR is coming out with a 9503 and an 11X Zero.
Nice thing about the JR XP9303 is that you can either use 72Mhz RF Modules or Spektrum 2.4 RF Modules. JR sells 9ch PCM Rx's and 9ch PPM Rx's and you can even get 9ch in 2.4. Flight Modes and Flaps on a Switch are a big plus.
Futaba, Hhitec, and JR have Synthesized 72Mhz RF Modules so you can Dial a Channel. JR even has a Synthesized 9ch 72Mhz Rx that can be set to whatever channel the RF Module is set to.
BuschBarber is offline
Old 01-08-2010, 01:46 AM
Campgems
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a 9c and a 9c super. My plan was to upgrade the 9C Super to 2.4, but when I got to pricing it out. I ended up going with a 10C. Igot the modular one, and there was special that have you a second receiver. Basicly, the cost of the 10C "body" was $40 over the cost of the upgrade, when you factored in the price of the receivers. I am only flying one plane on 2.4 right now, but Istill have my hanger full of 72 recevers in planes and the 10C modular really fits the bill. To bad that Futaba decided to go to dedicated 2.4 or 72 on the 10C.
There are some aftermarket 2.4 sets for the 9C, but I don't have any info on how they perform. The 2.4 RFmodule for the 10C will not fit the 9C, but I believe that the 9C 2.4 moudule will fit my 10C. Dont need it though.
The cost of 2.4 isn't so much the TX as the number of receviers you need if you have a fleet. That is the main reason I went with the 10C, I didn't obsolete any of my equipment.
By the way, $150 with two receivers is an OKdeal, if everything is really "Like new" It's not a great deal though. Two years back, it would have been a steal.
Once you get over the long antenna on the tx and rx, there really isn't that much difference.
Don
Campgems is offline
Old 01-08-2010, 10:46 AM
Zeeb
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry but I just don't see the reasoning in buying an obsolete radio and in 72MHz to boot....
I had a 9C Super for several years and thought it was a pretty great radio for a newbie, then as I got into bigger faster models the latency issue with the 9C became apparent to me. Some folks will say it's not an issue but the mismatched elevator actuation drove me to the 9Z which I used for a couple of years as well.
The control response speed of the newer 2.4GHz systems is something you have to experience to believe and is another good reason for sticking with that band besides the possible frequency conflicts on the 72MHz band. The other thing about that band is that lots of "toys" one sees at WallyWorld and even places like Harbor Freight are now coming in the 72MHz band vs. the 27MHz band they used to use, so you can have issues with the uninitiated playing with their toys and can ruin your day.
There are basically two types of 2.4GHz systems and although some folks like to get into arguments about which is technically superior, IMHO it's pretty much a moot argument; they both work. So it kind of comes down to what features you want in the tx, how it feels in your hands and the availability/pricing of rx's for various applications.
When it comes to things like the Bind 'n Fly stuff, that's pretty much restricted to one system/brand which happens to be the one you're using. If that or the number of rx's available is important to you then the Spektrum/JR stuff is probably the way to go. On the other hand, some of the late comers like Hitec and Airtronics are producing tx's with more capabilities but rx availability is currently somewhat limited.
This kind of question usually produces some brand wars, so just take the input you get and look at what's available. What others in your area/club use might be a factor since they can help you with getting to know the radio. It might boil down to which feels better in your hands. If at all possible, you ought to consider hitting the LHS's and see if you can actually hold one in your hands.
Zeeb is offline
Old 06-09-2015, 04:58 AM
skybolt58
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anybody know what is a good battery to run in the Futaba 9C super synthesized? I was told by someone you can run a lipo in it, but Futaba support says no here is what futaba says?
Thank you for your recent e-mail.
Futaba has no recommendations for any
batteries other than the stock ones that
come in their transmitters. Use of anything else can cause harm to the internal
portions of your transmitter and
will void any warranty it may have.
The average flight times of the stock
batteries is normally sufficient for any
pilot during any standard day at the
field.
Should you have any further questions or concerns, please do not
hesitate to
contact us at this email address. Please be sure to copy all
previous emails
into any future questions. You can also reach our product
support technical
team at 217-398-8970, or via fax at
217-398-7721.
Sincerely,
Krysta
Product Development &
Support Specialist
Futaba Service Center USA
On Sat Jun 06 01:31:41 2015,
rschaniel@twcny.rr.com
wrote:
> Hi
> I have the 9C synthesized Transmitter
and someone told me I could use
> a lipo battery in it, Is this true? and
what is a good battery to use,
> the stock one which is only a 600mAH
NiCad is about at its end of
> life,
> Ron
skybolt58 is offline
Old 06-09-2015, 07:00 AM
TFF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get an enloope replacement battery
TFF is offline
Old 06-09-2015, 11:10 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A good option, but a pricey one as well.
Here's a good another option for your Tx.
http://www.valuehobby.com/power-syst...h-3s-life.html
If you have a Lipo charger that has a LiFe setting, then you're set to go.
Pete
pilotpete2 is online now
Old 06-09-2015, 11:05 PM
chuckk2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 2.4ghz module set is too pricey!
If you were closer, I'd be happy to sell you a used 9C with a synthesized 72 tx module, and an RX to go with it!
chuckk2 is offline
Old 06-10-2015, 07:44 PM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does any one have schematic for the 9C Super. A friend has one that is totally dead. No read out on the screen. His battery checks OK.
sidgates is offline
Old 06-11-2015, 07:04 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That Futaba PCM has very poor latency. If you put elevator on two different channels you can see 1/2 the elevator lag the other about 5 degrees when you move them. Makes for screwy flying.Using PPM is better but then you lose about 3db in sensitivity. That is equivalent to cutting your tx power 1/2.
That radio was excellent for its day. That day is over.
dirtybird is offline
Old 06-11-2015, 07:44 AM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My friend with the dead 9C is using a 2.4GIG RF on PPM so he could see the latency you talk about. I have a 9C with the Weatronic RF module and Weatronic 12Ch Micro receiver. As you may know you can program the receiver to use more than one output on the same input signal. As far as I can tell then the 2 servos start at the same time.
sidgates is offline
Old 06-11-2015, 11:10 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In my installation I had a servo on each side of the fuselage. In order to keep the geometry correct, I had to reverse a servo. Futaba servos are not easy to reverse so I connected one to channel 2 and the other to channel six and inverted it(6). It is my understanding that to fit 1028 bits into the bandwidth restrictions on 72 it required two updates.So PCM required two updates. PPM did not need that and so its latency is 1/2 PCM.On 2.4 you have plenty of bandwidth.
I updated my 9C to XPS where all outputs are output simultaneously. Wheatronics may do the same. But you are still stuck with the latency of PPM
Old 06-15-2015, 06:33 PM
JPMacG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an Eneloop pack in my 9CAP. I am very happy with it. I used to have just a NiCd pack and I liked that fine too. I would avoid lithium for a transmitter.
JPMacG is offline
Old 06-16-2015, 12:44 PM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The radio doesn't know or care what the chemistry of the battery is What matters is that the voltage of the battery is correct. A 3S Lipo in your radio is not a good plan, a 3S LiFe is a great alternative to an 8 cell Nimh pack in any radio that uses an 8 cell pack. Newer radios are being designed for use with 2S Lipo and LiFe.
Pete
Reply
Display Modes
