JR 10SX Lnd switch
My Feedback: (27)
JR 10SX Lnd switch
How do I turn on land switch when in the mid position in conjunction with code 66?
When I move the switch to the mid position, it always reads off. Therefore I am unable to tmake the flaps come down in that position when using code 66 .
Thanks, KRC
Thanks, KRC
My Feedback: (-1)
JR 10SX Lnd switch
You can't...that is the default position for 'off'. This is done as a safety measure so you can't inadvertantly flip through 'land' while trying to flip into e>f mix or vice versa. Because this is a 3 position switch you want to setup flaps so that the switch is flipped toward you. It's intuitive also...switch down, flaps down- switch middle off- and switch up e>f mix. Hope this helps.
