RANGE CHECK BUTTON SPECTRUM 9000
My Feedback: (41)
just put a new 2.4 set up in my jr 10 x.is says there is a button to push for range check.. i dont see one!! its the module with the antenna built in ,no wires to jump.. works god on the bench.binds ok . i dont want to fly it untill i do a range check..
AB, CANADA
RE: RANGE CHECK BUTTON SPECTRUM 9000
If you were able to bind them together then you have found the range test button. One in the same, it will get more clear as you play with it more.
Enjoy, -Snuts-
Enjoy, -Snuts-
