Broken TX Antenna!
Broken TX Antenna!
Hi
I just broken my Futaba SkySport Transmetter antenna ..
I replaced it with a radio antenna that came a little bit shortter
the plane flys at a good distance so far .. But I have been told that I must get the EXACT antenna length.. not even taller!
is that right ?? and what do u recommend guys ?
AbuAnas
AbuAnas
My Feedback: (19)
WA
Broken TX Antenna!
AbuAnas,
If it is just a little short and your range check works good, than I guess you are OK. Anyway, a replacement futaba antenna does not cost that much if this has got you worried.
Azhar
Azhar
UT
Broken TX Antenna!
Strictly speaking from an electronics standpoint, you should replace it with the EXACT same length. The length of the antenna is designed to create optimum output, and if you go slightly (1 or 2 inches) shorter or longer, your radiated power will be reduced, and more of the signal will be reflected back into the transmitter electronics.
You probably won't see the difference during a range check with collapsed antenna, since the collapsed antenna length will be almost identical between the two.
Broken TX Antenna!
Azhar
Thank you for your input..
Your name sounds Arabic
strato911
It seems the situation here, I think the guy is working in the field of comm's and knows about those things
So where can I find a futaba replcement online ??
AbuAnas
strato911
AbuAnas
UT
Broken TX Antenna!
Originally posted by AbuAnas
strato911
strato911
Any RC supply company which can sell Futaba equipment can sell you a proper replacement. If they don't have it in stock, they can order it. Online, you can order it here: http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=MZA
My Feedback: (506)
Re: Broken TX Antenna!
Hi
Hi
Had them stepped on... snapped them while collapsing them... poked other modelers by accident... etc.
The final straw? Got it tangled in my hi-start line... launched the sailplane, then the TX. Broke *everything*
Time for a Duck
