Futaba 8UA question
Reply
Old 03-08-2010, 08:45 PM
Tcat1000
My Feedback: (34)
Tcat1000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba 8UA question
Hi............Just installed the Futaba 2.4 conversion in my 8UA TX. Do I have to unscrew & remove the old collapsable antenna or just lleave it in? I have installed the 2.4 kit & it works fine, but am worried about the OEM antenna maybe causing problems. ???????????????????
Thanks in advance
Tcat
Tcat1000 is offline
Old 03-09-2010, 12:08 AM
Bozarth
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba 8UA question
Leave it in. No signal is passing through it if you have the 2.4 module installed.
Kurt
Bozarth is offline
Old 03-10-2010, 03:30 PM
rt3232
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is ok to take it out but be sure to plug the hole.
Bob T
rt3232 is offline
Old 03-10-2010, 04:15 PM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you do switch totally to 2.4Ghz and want to remove the buggy whip as I did, check your local hardware store, my True Value had a selection of black plastic trim plugs that fit my 9C like they were made for it[8D]
Pete
pilotpete2 is offline
Old 03-10-2010, 07:52 PM
Tcat1000
My Feedback: (34)
Tcat1000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the replies. Now that it was mentioned, I remember having some black plastic plugs that should work for plugging the hole. Out it comes................
Thanks again
Tcat
Tcat1000 is offline
