Monitor ?
NM
Monitor ?
Can a small speaker, or earpiece be attached to the output of a receiver to act as a monitor ? We use to do this years ago using superhet receivers, but I am not sure if it can be done with present day receivers ?
UT
Monitor ?
Just my opinion, but that would seem like a tragic waste of battery capacity (and needless noise), except when the plane is lost after a crash.
There are products on the market (inexpensive) which sound an alarm when the receiver no longer receives a signal, so after a crash, you just turn off your Tx and follow the sound.
NY
Monitor ?
Because GeeBee it's used only on the ground, what point is there to have one in a receiver that's designed to work in the air? It adds weight complexity and yet another failure point (regardless of weather or not it's being used) That's why they only make stand alone units.
UT
Monitor ?
Originally posted by GeeBeeJim
Errrr, you don't understand Strato. A "Monitor", is used on the ground, to determine if you have a clear frequency to fly on.
I didn't think of that since my Tracker II has an integrated scanner which won't even turn on the RF circuitry until it verifies there's no interference on your channel.
NM
Monitor ?
........ Ohi Vey ......... I give up already.
One more time, and then I will give up. - A monitor is used on the ground to "monitor" the frequency that you are using. IT IS NOT USED IN THE AIRPLANE ! It is used on the GROUND, just like a scanner, except that it just listens to a single channel, preferably the channel that you are using. It is used used to check for potential interference on your frequency before you fly.
YOU DO NOT INSTALL IT IN YOUR AIRPLANE ! ! !
If you do not understand this long used concept. please do not reply.
UT
Monitor ?
IF you want to, you could still hook one up. The PPM pulses which the Rx would normaly send to a servo create a quiet, but audible sound if a speaker is hooked up between the servo signal wire and ground.
If the Rx has no incoming signal, it doesn't send anything to the servos, so no sound from the speaker.
NM
Monitor ?
Thanks Strato, you are right. Easy enough to try, and I have plenty of spare Rx's. That'll answer my question best. I'll build up a small unit that will fit in my shirt pocket.
Thanks > Jim
Thanks > Jim
UT
Monitor ?
Jim - I tried it even before I replied... It works, but like I said, it isn't very loud. Perhaps a speaker with a different impedance would have been louder (mine was 8 ohm)... or add an audio amp with volume control
NY
Monitor ?
Can a small speaker, or earpiece be attached to the output of a receiver to act as a monitor?
NM
Monitor ?
Originally posted by Lynx
Sorry GeeBee but from what you asked that would have to go up with the airplane as the receiver is definitely used on the plane.
SHEECH ! Read the posts, and then try and understand what you are reading !
Moderator, this guy has gotta be trolling. Please close the thread.
My Feedback: (10)
GA
Monitor ?
Well... I can understand the frustration, a bit. I got frustrated just reading it
Look at the line you quoted, and try to imagine how an earpiece would do any good,
if it was installed in the plane. Receivers can be powered up in lots of places
besides planes. I know a person once who rigged an old transmitter with servos
from the inside... and a receiver, battery, etc... so you could follow someone's stick
movements while they were flying. (for standard 4-channel setups, of course)
