FUtaba FASST 2.4GHz question.
Hey guys, I've got a Futaba "FASST" system, I believe it's the 3PM. It's 3 channel, 2.4Ghz.
Anyway, I'm wondering if I can use the receiver in a Duratrax Vendetta ST (electric). The battery that powers car and radio is 7.2v, a 1.6v increase from what the spec for it is.
Is the receiver capable of handling this voltage increase or is it just gonna fry?
RE: FUtaba FASST 2.4GHz question.
The ESC normally has a BEC circuit that regulates the voltage to the receiver and servos to 5.1V normally. Most receivers could handle the 8.4V of a fully charged 6 cell battery, most servos cannot.
Pete
Pete
The 603FF and 603FS can both handle that voltage, no worries. But as was said above, the BEC likely is dropping the voltage down to 5 volts or so. Most receivers can handle quite a bit of voltage. What limits the voltage is more the servos than the receivers.
Alright thanks!
New question:
How do I set up (connect) the FASST receiver so that both the throttle and the steering will work? I can't seem to get any throttle response out of it.
Thanks.
New question:
Thanks.
I don't think it's the receiver that's causing the problem now. I cannot seem to get the stock radio to respond to throttle input either. I dunno what the hell happened, it was working fine, sat on a shelf, and now won't work. Duratrax JUNK!
